PNF vs PRB Kpro unit
Old Nov 13, 2010 | 11:38 AM
kaissi's Avatar
Default PNF vs PRB Kpro unit
I have a friend of mine who has a PNF kpro on his K20 Type R Civic.... He wants to sell the unit.. can I use it for S2000.. I will buy the parts needed like valve cover tdc sensor/wheel..etc.. but does the PNF ECU work?!
What's the difference between PNF and PRB anyway
Old Nov 14, 2010 | 12:40 AM
S2kAndTheAnt's Avatar
The hondata website says to only use the PRB. So I would assume that is the only one that will work on it.
Old Nov 15, 2010 | 10:38 AM
kevos2k's Avatar
you need a PRB ecu... and its not just plug and play if you were to buy a kpro PRB it still would not work and would need to be sent to hondata to be made into a s2000 version... it uses a diffrent circuit board that the k series hondata ecu's
Boofster
Sep 16, 2011 04:12 PM
SHEPSS2K
Feb 19, 2009 10:49 AM
jdnissanz
Jul 10, 2007 02:57 PM
