Quick kpro question?
Engine management topics, map and advice.
Mar 25, 2010 | 11:20 AM
0piston
Aug 2003
Vancouver
Does the KPro handle the EVAP system, or is that function seperate from the oem ECU?
thanks
0piston
Find More Posts by 0piston
Apr 2, 2010 | 06:23 PM
96-EJ6
Mar 2007
KAIZENSPEED, WA
I believe the K-Pro controls it...Hondata????
96-EJ6
Visit 96-EJ6's homepage!
Find More Posts by 96-EJ6
Apr 2, 2010 | 07:12 PM
spectacle
Sep 2004
Tampa, FL
No control in the kpro
spectacle
Find More Posts by spectacle
Apr 3, 2010 | 05:49 AM
dstevens
May 2006
EVAP is controlled by the ECU. KPro will run it correctly as long as
OBDII' is switched on, which it is by default.
dstevens
Find More Posts by dstevens
Apr 5, 2010 | 09:26 AM
Irishflame27
Mar 2009
avondale AZ
so can the evap system be removed? meaning the purge valve and canister and all that stuff, and still pass the readiness tests?
Irishflame27
Find More Posts by Irishflame27
Apr 5, 2010 | 10:19 AM
DFWs2k
Oct 2005
Denton, TX
yes evap stuff can all be removed
DFWs2k
Find More Posts by DFWs2k
Apr 5, 2010 | 10:40 AM
Irishflame27
Mar 2009
avondale AZ
DFWs2k,Apr 5 2010, 10:19 AM
have you done so? Does your car pass the emission readiness tests? no CEL?
Who’s Here in Wee Hours VII
12.4k
393.1k
All Things Automotive
6.1k
290.5k
How to speak New England(ish)
20
281
Interestng YouTube videos (do you have a favorite?
200
5.6k
The World Cup is coming.
23
380
Irishflame27
Apr 5, 2010 | 06:17 PM
96-EJ6
Mar 2007
KAIZENSPEED, WA
I doubt it would pass with the EVAP system removed.
96-EJ6
ecu reset question?
s2kking
05:03 PM
vacuum leak question
thienizm
12:09 AM
cel code p1607
tru
02:37 PM
Dumb question but does resetting ECU make engine run better?
hyperpm
Dec 23, 2002
06:56 PM
Back to Subforum
View Next Unread
Kpro Question: Map change on the fly
04:14 PM
