REading AF on Flashpro datalog
Old Jun 2, 2010 | 04:52 PM
Ludicrous Speed's Avatar
Default REading AF on Flashpro datalog
Just started playing with my flashpro this week.
I decided to load the Toda tune as I have the Torquie header, T1R straight pipe and sparrow 2.0 exhaust.
When I'm reading back the data, the AF is spiking when I'm changing gears or when I'm letting off the throttle. It's typically giving a read of 29.4 on the spike.
Is this normal for being off the throttle?
Sorry, just learning.
Old Jun 2, 2010 | 06:28 PM
H22toF20's Avatar
The injectors stop when you let off the gas, untill you get back on the gas or the RPM's drop to an idle. So this lean number is 100% normal. It's weird that it reads that lean though, most widebands read 10-20:1 A/F.
Old Jun 2, 2010 | 06:51 PM
I have the secondary O2 sensor disabled, would that explain the higher readings?
Old Jun 2, 2010 | 07:30 PM
JustinC's Avatar
no, whenever you go off throttle KPRO reads down to 32:1, don't sweat it, its normal
Old Jun 2, 2010 | 07:32 PM
Cool, thanks to both of you.
Old Jun 3, 2010 | 05:34 AM
Gernby's Avatar
Former Sponsor
You would see the same thing with the stock tune.
Old Jun 3, 2010 | 12:38 PM
s57_s2k's Avatar
it is called de-acceleration Fuel Cut Off . for fuel economy and to make engine speed drop faster .
Old Jun 3, 2010 | 01:59 PM
leftme's Avatar
My 1995 GTI did the fuel cut on decel and I was going to ask if it would be ok to do this with the flashpro on the S2000 or if Honda already does it.
Clayton
Old Jun 4, 2010 | 12:02 AM
H22toF20's Avatar
To my knowlege, all modern factory ECU's do this. I'm sure all of the aftermarket ones do it as well. There's no reason to dump fuel into a cylinder that is getting zero air.
kikkomon
Mar 24, 2019 04:15 AM
S2K9grand
May 2, 2014 06:13 PM
Metcalfe
Jun 27, 2013 12:34 PM
Tedow
Apr 22, 2004 12:57 PM
