s2000 ecu pins and connectors
Old Aug 29, 2012 | 12:00 PM
crash's Avatar
Default s2000 ecu pins and connectors
I have just ordered all of these pins and connectors and will verify if they are proper when they get here.
but from all my hours of research they are the right ones.
I spent days looking for all of them and I could not find them in 1 place so now they are right here.
Small connectors 175265-1
http://www.onlinecom...html?p=10264290
http://www.te.com/ca...n.y=12#features
[attachment=26492:2012-09-05 18.28.57 (Large).jpg]
Big ones 175268-1
http://www.te.com/ca...268-1&PID=20455
http://www.onlinecom...html?p=10264295
[attachment=26493:2012-09-05 18.27.56 (Large).jpg]
here is the power connector 32 pin grey 179681-6
http://www.te.com/ca...681-6&PID=95742
http://www.onlinecom...html?p=10268086
[attachment=26494:2012-09-05 18.27.41 (Large).jpg]
blue 31 pin connector 179680-5
http://www.te.com/ca...680-5&PID=95741
http://www.onlinecom...html?p=10268085
[attachment=26495:2012-09-05 18.27.47 (Large).jpg]
and the last connector I think 25 pin grey 179679-6
http://www.te.com/ca...79-6&PID=108707
http://www.onlinecom...html?p=10268084
[attachment=26496:2012-09-05 18.27.34 (Large).jpg]
Attached Thumbnails s2000 ecu pins and connectors-2012-09-05-18.28.57-large-.jpg   s2000 ecu pins and connectors-2012-09-05-18.27.56-large-.jpg   s2000 ecu pins and connectors-2012-09-05-18.27.41-large-.jpg   s2000 ecu pins and connectors-2012-09-05-18.27.47-large-.jpg   s2000 ecu pins and connectors-2012-09-05-18.27.34-large-.jpg
Old Aug 29, 2012 | 01:25 PM
Gernby's Avatar
Former Sponsor
Which ECU are these for? I believe there are 2 versions ('00-'05 and '06+).
Old Aug 29, 2012 | 04:37 PM
crash's Avatar
these would be for the 00-05 but I don't know if they are different between the two on the pins and connectors
I don't have a later model harness to look at either
I just got tired of calling wiring guys and them not willing to give me the info or even sell me the pins.
and I didn't want to spend the 60 bucks aem wants for the kit
all in all those parts with 100 small pins and 40 big ones was 37 bucks I think.
but if your just fixing a few wires or adding for the aem or hondata or any of the others you can order in smaller quantities from that site I linked.
also they sell Raychem DR-25 heat shrink by the foot as well and for a good price.
the other place I have been going to for wiring stuff is Prowire.com
Here is my rebuild thread which is where all of this came from
https://www.s2ki.com/s2000/topic/932...ld-and-rewire/
Old Sep 5, 2012 | 05:59 PM
crash's Avatar
ok so I got these in and figured I would add the pics to the post.
they are the right ones for 00-05 and maybe the newer ones too
Old Sep 6, 2012 | 09:07 PM
miguel329's Avatar
Thanks for sharing, wire guys never reply when i ask where i can get pins... You plan make a tucked harness?
Sent from my PC36100 using Tapatalk 2
Old Sep 7, 2012 | 09:22 AM
crash's Avatar
no I did this to make a race harness.
I removed all kinds of stuff I did not need and re-routed the harness to go down where the wiper motor used to be so all the wires were different lengths.
Attached Thumbnails s2000 ecu pins and connectors-2012-08-28-15.31.30-large-.jpg
Old Sep 15, 2012 | 05:56 AM
eastcoastbumps's Avatar
Great work! Do you have the part numbers for the female/ECU side? It would be good for anyone going to a standalone ECU that wants to plug into the factory harness.
Old Sep 15, 2012 | 07:04 PM
crash's Avatar
Hey Eastcoast,
Just looking at one of the plugs and read one of the pdf's which had this pic in it
[attachment=27168:connectors.jpg]
From that I found this
http://www.te.com/ca...6?RQPN=179686-6
and this
http://www.te.com/ca...6?RQPN=179684-6
first one is 104 pin and other is 79 pin.
I dont have the ecu in front of me but I think its the 104 pin one.
Glad I could help
Old Sep 18, 2012 | 08:43 AM
pastoli's Avatar
You are the man! I need to make a adapter harness for my standalone ecu. I need to re route some wires that I am having electrical noise problems with and this will allow me to hopefully fix my problems.
Old Sep 18, 2012 | 11:13 AM
Manny2587's Avatar
I need help ASAP. I have a 06+ using flashpro with boost control. I'm trying to pin the factory harness to use the boost control function. I tried using a pin that came with my buddies aem EMS for his 00-05 and it won't go in the connector all the way. I'm assuming the 06+ pins are different, where can I get these!?
