s2000 ecu pins and connectors
Old Jan 25, 2015 | 11:18 PM
  #21
bigearl91's Avatar
Can anyone confirm this is the 104 pin connector?
My plan is to make my own harness for splicing so I am not cutting any of the factory harness., I think this is the best way to go about doing it.
Cheers
Earl
Old Apr 27, 2016 | 03:39 PM
  #22
boostinbort's Avatar
Does anyone know where i could get just the plastic connector piece on the ecu / ecm?
Old Apr 23, 2020 | 06:29 AM
  #23
RAIN H8R's Avatar
2020 bump.
The big pin is 175269-1, not 175268-1. Whats the big difference?...the tang that you crimp the wire strands to is 3.5mm long, not 3mm (which is what 175268-1 has)
Old Jun 3, 2020 | 04:30 PM
  #24
Madvtecbro's Avatar
Originally Posted by RAIN H8R
2020 bump.
I am trying to find the correct pin to use to connect to b12 for my wideband to be able to datalog, are the numbers you listed for an 06+ or 00-05?
Old Jun 3, 2020 | 06:15 PM
  #25
RAIN H8R's Avatar
these are for 00-05. Not sure what pins are needed for 06-09. But once you find out, please share the info, please PM me.
Old Jul 18, 2020 | 10:23 AM
  #26
Sub's Avatar
Sub
2020 bump.
175269-1 and 175268-1 are the same pins. The difference is just in nominal wire size.
175268 = 0.3-0.85 mm^2
175269 = 0.5-1.25 mm^2
You can check this info at te.com in application specification ENG_SS_114-5160_J.pdf
liquidgsr
Sep 1, 2012 05:35 PM
Ste_Nova
Jan 30, 2008 08:42 AM
macspeed704
Nov 5, 2005 06:56 AM
SMacke
Sep 3, 2004 10:05 AM
