s2000 ecu pins and connectors
Old Sep 18, 2012 | 12:06 PM
crash's Avatar
in all honesty I would just call someone that deals with flashpro and get a single pin or a few.
it took me hours to figure out what pins go in the 00-05 cars and I had ordered 2 pins that were not correct.
and Thanks Pastoli
if you end up ordering the ecu side connector post in here if it is the right one or not.
I did not order one as I dont need it but everything is telling me it is
Old Sep 18, 2012 | 12:13 PM
pastoli's Avatar
I need to figure out what wire to use to make this jumper harness. Can you shed any insight on what you used? I also need to get some shielded cable wire.
Old Sep 18, 2012 | 04:50 PM
crash's Avatar
if I were to do it I would use anything from this page
http://www.prowireusa.com/products.asp?dept=75
this place is also good for stuff
http://www.aircraftspruce.com/menus/el/wire.html
if you have questions just call prowire they have been very helpful for me in the past and I buy all my deustch connectors from them.
as for wire size I am almost positive 22 gauge is fine
prowire.com and onlinecomponents.com have very similar pricing but prowire is just motorsport related so its easier sometimes to navigate their site
Old Sep 18, 2012 | 10:41 PM
Manny2587's Avatar
For future reference, I found out about 06+ ecu pins. I called hondata and all they could tell me was that they think the 06+ pins are the same as the rsx. That being said, I have a buddy who is a tech at Acura so I swung by the dealership. All dealerships have a re-pining kit for the shop to use. We went through the kit and I found the correct pins, which have a smaller opening at the end where the male pin is inserted than the 00-05. I grabbed a few so if anyone is in dyer need of some let me know..
Old Sep 19, 2012 | 12:35 PM
pastoli's Avatar
You sir have a Email.
Old Sep 20, 2012 | 02:47 AM
Manny2587's Avatar
Pm'd ya
Old Sep 26, 2012 | 12:29 PM
hondacivic90ed's Avatar
Email sent.
Old Sep 26, 2012 | 01:02 PM
Manny2587's Avatar
Replied and I will send you a couple. That's the last 2 I have. I will talk to my buddy and try to get a bunch more.
Old Nov 17, 2012 | 09:34 PM
pastoli's Avatar
I was reading another thread and came across these links.... Cheers.
http://www.easternbeaver.com/Main/El...SMHW/smhw.html
http://www.newark.com/tyco-electroni...roduct+Catalog (I order from these guys for stuff at work.)
http://www.summitracing.com/parts/AV...00-S/?rtype=10
Old Nov 19, 2012 | 08:45 PM
Manny2587's Avatar
I have some more 06+ ECU pins "in stock." PM me with your needs.
