Sending ECU for PWM mod for 06+ ECU w/ Flashpro
Old May 7, 2017 | 04:14 PM
Memo6453's Avatar
Default Sending ECU for PWM mod for 06+ ECU w/ Flashpro
Has anyone with a 06+ sent their ECU to Hondata for the PWM Mod to allow boost control by Flashpro? any insight on how to do this including how to box up the ecu and make sure everything goes smoothly? how long does the process take total? is the Hondata map sensor and 4port solenoid required? or does any map sensor ie. SOS 3bar and MAC 3-port solenoid work just as well?
Old May 9, 2017 | 03:27 PM
RAIN H8R's Avatar
contact Hondata directly for this request. They usually have next day air back to you. You need a map sensor over 10 or so psi. I run SOS map, doesnt matter as lomg as the range is within your build maximum.
Old May 9, 2017 | 05:19 PM
R00567's Avatar
1) go to their website
2) print the order sheet for that modification
3) send it to them
4) turn around is fast and it lets you add a MAC solenoid for boost by gear.
Had my 2007 ecu done and they were very fast and responsive.
trig06
Feb 2, 2019 04:08 AM
Dizings2k
Jul 16, 2018 11:58 AM
Croc
Apr 14, 2014 04:01 AM
kawasake
Nov 21, 2010 04:15 PM
