Throttle Injection Correction/VTEC Fuel Add
Old Oct 6, 2012 | 11:43 PM
mrscbw's Avatar
Default Throttle Injection Correction/VTEC Fuel Add
Alright, I'm trying to figure out how I can correct this issue I am having, hopefully some AEM EMS pros can chime in on this.
The problem I am having right now is that the fuel map is mapped correctly for WOT @ specific loads. But, there are times when WOT and 40~60% part throttle is equivalent in load(which means they will use the same fuel map cell). However, it is running significantly richer compared to WOT @ same RPM&Load. I am guessing this is due to VTEC not engaged at part throttle <60% (this is where my VTEC engagement is set) or could it be somethinh else?. Now I'm thinking I have to use a VTEC fuel add while tuning the fuel cells for non-VTEC or create a throttle injection correction fuel trim table. VTEC fuel add worries me because there is no table and you can only specify a % across the whole RPM band. Is this going to scale properly all the way to redline based on the fuel map?
I am leaning towards the Fuel injection correction table but I'm wondering if this is the right direction.
Have anybody else ran into this problem?
Old Sep 30, 2014 | 04:35 PM
KEVIN8086's Avatar
No replies? That sucks. I'm having the same issue
Old Oct 2, 2014 | 04:23 AM
VTEC2000's Avatar
Can you post your trim table(s)
always@9k
Apr 24, 2013 10:51 PM
Gernby
Sep 30, 2010 10:24 AM
dayves2k
Mar 4, 2004 03:25 PM
dayves2k
Nov 7, 2003 11:01 AM
s2knikko
Sep 29, 2003 08:35 PM
