FlashPro - Throttle pedal position
Old Mar 17, 2010 | 11:44 AM
ace123's Avatar
Default FlashPro - Throttle pedal position
Noticed when looking at the datalogs that my throttle pedal position at WOT is only 92%, not 100%. Is that common, and can/should I change it?
Throttle plate goes up just past 100%, so maybe that's all that matters. It just seems a bit odd.
And yes, it's pig rich in this part of the log, though 12.5:1 is what it's been running generally... I've got work to do. I'm also at 4500 ft altitude, so I wonder if that makes things different for me.
Old Mar 17, 2010 | 12:26 PM
macr88's Avatar
Read the help file in the hondata program. They're trying to address this and might have already with the new update.
Old Mar 17, 2010 | 12:41 PM
scareyourpassenger's Avatar
I fixed mine and re-dynoed. I got another 8% more power!!
Just kidding
I do show in my latest log a 99% though.
Old Mar 17, 2010 | 02:13 PM
ace123's Avatar
I looked at the descriptions after using the help file search, but I couldn't find enough detail to tell what the two (pedal position vs plate position) meant any more than what the names seem to imply. Maybe I just need to dig through it some more. And I just got the software yesterday, so it should be current, and I'll have to keep looking for new releases.
Just kidding
Yeah, that's exactly what my first thought was! Obviously not, but the nomenclature sure does make it sound that way.
It makes me curious as to what the sensor reading is really saying though. It looks like throttle plate position shows pedal position with respect to WOT, but even if so, what is pedal position there for?
It looked like the kind of question that would have a quick answer, so after searching hondata's help quickly and searching s2ki with no results I just figured I'd ask. I'll post up if I find more of the answer.
Old Mar 17, 2010 | 04:11 PM
There may still be some issues but according to the release notes it was fixed.
V1.1.4.3 (9 February 2010)
· FlashPro firmware updated to version 14.
· Changed datalogging so the MAP sensor is datalogged beyond 2.55 bar absolute pressure.
· [Civic Si] Added boost cut.
· [Civic Si] Added cranking fuel table.
· [Civic Si - Race] Added boost control output.
· [Civic 155hp - Asia] ECU part numbers 37820-RRH-U120 and 37820-RRH-U130 added to list of supported models.
· [Civic Si - South America] ECU part numbers 37820-RRD-M120, 37820-RRD-P120 and 37820-RRD-P210 added to list of supported models.
· Support for ECU part number 37820-RRB-K120 renamed from 'South America' to 'Central America'.
· [S2000] - fixed throttle pedal datalogging as 91% when at full throttle.
· [S2000] Added P0128 and P0456 DTC disable flags.
Old Mar 17, 2010 | 06:05 PM
ace123's Avatar
Ok, so it's a bug.
The latest release right now is 1.1.3.4, from 1/15/10, but they have a beta of 1.1.4.5 dated 3/2/10. I'll either update to the beta or wait and forget about it.
Old Mar 18, 2010 | 07:06 AM
Gernby's Avatar
Former Sponsor
I strongly urge you to stick with the "production" releases of FlashPro manager, and let other people test the beta versions. Hondata doesn't seem to have much of a testing team, and have let some really scary software bugs pass through. As a novice tuner, I could easily have blown my motor with 1.1.2.6.
Old Mar 18, 2010 | 08:29 AM
ace123's Avatar
Thanks for the warning!
I haven't learned much about FlashProManager yet, so I was thinking I would want to play it safe until I at least know what I'm doing. It seems like a great product for $700 though!
Gernby
Jul 21, 2016 05:59 AM
cheddaboy
Aug 29, 2015 11:55 AM
pedrobaby77
Jul 14, 2010 05:59 PM
whiteflash
May 25, 2010 07:24 AM
Rollinx25
Jan 17, 2008 04:59 AM
