Using the RSX wideband with the Kpro
I did it! It worked great. I triple checked the wiring. Just some info the 02 sensor is
1 - 2
3 - 4
looking from wire side on female connector or looking from terminal side on male connector.
Just FYI, I have the newest Kpro as I just got it a month ago. I didn't check which revision I have. I just verified the pin out with my kpro on the race car. Didn't seem they changed the D connector pin out. Everything is as described on Justin C diagram.
I have a feeling ShadowPh0x situation is wiring issue. Like JustinC mentioned, Hondata made a mistake before. It's also possible ShadowPh0x made a mistake in wiring it up. After all we are all human.
1 - 2
3 - 4
Had the PC connected at the time... not blown fuse, just burnt smell... and TPS/ECT/Sec02 sesnors went overvoltage. Shut the car off immedately (was still running)
Worked perfectly for two weeks... too pissed right now to write comments...
Yes, the wideband was still functioning when it died-no codes for it at all.
Wow, sorry to hear. I'd like to know if you re-checked your wiring after the burnt? Now, you got me nervous. So the only guy that has this running for a long time and no problem is JustinC?
I did triple check my wiring. Been running this way on my Tsx race car for 2 years now. I'm going to check it again
Kinda dousche on the end of Hondata to not offer this to us as a supported option, those of us who have the cash for Kpro could care less about the extra price to have the wideband option on it.
The reason they are so secretive about everything is they probably dont know what the hell they are doing either, im sure they dont offer this mod because they have no effing clue to how do it properly either and then dont want the extra work of all the units people would PAY to have revised. $600 extra to make this work, hell id shell that out no questions asked.
Im starting to think abunch of sociopaths work at hondata and hide in a dark room all day...
I remember one friends Kpro was acting oddly and they refused to tell us what the blinking lights meant that it was producing, seriously?!
If money doesnt motivate hondata, what would??? Im very confident that I could get a pre order list long enough to pay for this mod to become supported.
Ok, after I kicked the dog and punched the wife (figuratively , of course), I checked ALL of the wiring, the relay, etc. EVERYTHING was perfect. Below is a more simple sketch of the wiring. This is EXACTLY how mine is wired!
Reflecting back on it, I think it happened when the car is already 'warm'... and if the ECU turns on the heater anyway, there is no load from the heater. All of the current goes to ground via the ECU. I'm saying this b/c the D8 pin connection on the adapter board is burnt- it's the only thing on the D-plug area that is damaged. I had one other time when I started the car after driving it for a while when I though I smelled someing 'funny', but then it stopped. Nothing in the datalogs to inidcate there was a problem (no codes or sesnors acting funny).
If you have this mod, I would consider grounding the D8 (O2 heater ground) pin to the body rather than the ECU- see if it throws a code- I doubt it will. That way, if something does happen to the sensor, or the realy is on when the sensor is already hot, it won't ground out through the ECU.
PLX here I come... well, at least it gives me time to replace the brakes...
Originally Posted by rwheelz' timestamp='1305672363' post='20586144
Who can tell me how to convert my existing tuned map to a PRB map? The tuner made me a PRA map despite my specific request to have a PRB map, even though I explained why I wanted the PRB. I want to be sure I know what I am doing in terms of copying everything over so I do not miss anything!
and then go have it retuned, or then datalog and change fueling
Given hybridsol's post, I will be disconnecting it for now. And I will be doing it before I so much as turn the key, especially since it is useless currently. I would really like to have this safely installed and working in the end though.
Ok, mine stopped working and I yanked it out. Same, the track was burned and I lost continuity from A1 to D8. From reliable sources, I was told the adapter board doesn't have a good enough track to support that much current going through. You probably ok building a jumper between A1 to D8 with beefier wire, which is my next step. Cause I verified it with my race car K series running kpro and I run same exact wiring and been running fine.
Deff think this is the issue. Using my busted-ass ECU, I hooked an multi-meter between the ground return and body ground with the car running- meaured 5.1 Amps! The amperage decreased a little as the car warmed up down to about 4.7A. That's a lot of current for that little circut board to take...
Reading the Helms manual, it sems the ECU ALWAYS pulls in the relay with ingition ON, but uses the D8 gound to switch the heater on and off... maybe adding another realy to this (instead of the o2 gound->D8 use D8->2nd Realy control with return gound thru relay to body gound) would work?
