Valve Cover Question
Old Jul 27, 2010 | 03:49 PM
GpWaP1 s2k's Avatar
Default Valve Cover Question
Can the 04-05 AP2 valve cover be used if you have Hondata KPro on an AP1? I know the difference between the AP2 valve covers but I had mine powder coated and had bungs welded to it but now I need to go back to stock. I have only been able to find 04-05 valve covers. If I have the second camshaft position sensor hooked up will it cause any problems?
Old Jul 28, 2010 | 11:37 AM
jaundice's Avatar
If you are still using the KPro, the exhaust cam sensor needs the 06+ VC to clear. If you remove the exhaust cam sensor and go back to stock AP1 cam sensor and stock ECU, any VC MY'05 and less will work.
kjonesy203
Jun 4, 2018 08:15 AM
nshoes
Apr 27, 2018 10:24 AM
idragmazda
May 1, 2010 06:47 AM
YuriArts
Oct 14, 2007 01:05 PM
skibum
Oct 1, 2007 05:04 PM
