Weird Emanage Ultimate Issue
Old Jun 30, 2010 | 02:08 PM
lvd1102's Avatar
Default Weird Emanage Ultimate Issue
hey guys i have this weird problem that i cant figure out. Ok so here is my setup
EMU
Comptech S/C
FMIC
Exhaust
etc..
Now at first i had my map clamp voltage set at 2.85V everything worked fine for a couple days.
Couple days after it started to cut out at about 8000RPM. Huge stutter (like ign cut)
so now i put my map clamp voltage to 2.82V stutter goes away and everything is fine, no stutter or anything.
Couple days later the same thing happens again so i adjusted the voltage to 2.80V and stutter goes away again. this keeps happening and i have to keep lowering my voltage. right now im at like 2.76V.
i know everything is wired up correctly and im running about 6psi and i have the Greddy Boost pressure sensor.
What could be wrong?
Kitesurfer s2000
Sep 3, 2010 11:08 AM
SRap1
Aug 20, 2010 02:45 PM
Sub2K
Sep 26, 2008 07:01 PM
kylemonster85
Sep 17, 2008 11:27 AM
Wesmaster
May 15, 2004 04:18 PM
