NEED HELP W/VAFC SETTINGS
Old Jun 19, 2010 | 08:49 PM
swaps2000's Avatar
Default NEED HELP W/VAFC SETTINGS
I JUST INSTALLED MY VAFC 2 WITH THE JUMPER HARNESS ON MY AP2 2005
I FOLLOWED THE FACTORY SETTINGS WHICH ARE POSTED HERE ON THE FORUM AND MY CAR REDLINES @ 3000 RPM AND MY CAR HAS A CEL CODE.
BUT WHEN I TAKE THE VAFC 2 W/ THE JUMPER HARNESS OFF MY CAR RUNS FINE CAN SOME HELP ME OR GIVE ME SOME GUIDANCE PLS
THANKS
Old Jun 21, 2010 | 08:15 AM
s2konroids's Avatar
Check the settings in the vafc2 and check install of the wires and then double check - bet its a wiring problem.
Old Jun 21, 2010 | 09:37 AM
scors2's Avatar
sounds like the map signal is missing or the setting for the map is not right. look at the sensor display and see if the sensors are reading.
Old Jun 21, 2010 | 12:03 PM
Gernby's Avatar
Former Sponsor
Take it to an AutoZone, and have them pull the diagnostic code.
Old Jun 23, 2010 | 07:02 AM
SRap1's Avatar
post your setting and maybe we can help better, whats your initial setup look like, i just installed mine and it works great maybe i can help you
Old Jun 24, 2010 | 12:01 PM
vehicular's Avatar
I bet the MAP setting is wrong. I recently bought a DSM with a 'bad tune' that turned out to be the MAF/ MAP settings all backward.
Old Jun 25, 2010 | 03:23 PM
swaps2000's Avatar
I have the jumper harness its plug and play. Can someone maybe post there settings that they have there's to?
Old Jun 25, 2010 | 05:35 PM
Gernby's Avatar
Former Sponsor
Sorry for posting that last tongue lashing that I just deleted...
Old Jun 27, 2010 | 02:36 AM
SRap1's Avatar
sensor no; in 06 out 06
cyl: 4 thr: up and to the right arrow vtc: 1
Old Jun 27, 2010 | 02:37 AM
SRap1's Avatar
before you do these setting go to initilaize to clear out any previous settings... you may have some fuel adjustments that are screwing up the car....
mustangkiller01
Aug 13, 2006 06:40 AM
KYS2000
Jun 10, 2003 09:25 PM
02spas2k
Apr 25, 2003 07:33 AM
GDPzS2000
Dec 31, 2002 08:15 PM
