06+ Knock Sensor on AEM V2
Old Oct 13, 2015 | 07:17 AM
nMeOnE's Avatar
Default 06+ Knock Sensor on AEM V2
I am doing some data logs on my car and it seems as if my knock sensor might be off...
Setup is 08 s2000
AEM EMS V2 version 02v2
Running Pump 93
SOS Novi 1200 with a 3.4" pulley
I am trying to get it fine tuned for 93 first and then tune it for E85 then interpolate the two.
I got a baseline reading of knock at 100 octane already and it showed 0 knock and knock voltage never went above 0.09v and remain constant as RPM went up.
Run the 100 octane clean off the tank and did a 93 run and it showed the same results. I dont think my 93 octane from Sunoco is that good to not show any knock at all...
Here is my 100oct run
and two of my 93 runs
Old Dec 11, 2015 | 09:04 AM
nMeOnE's Avatar
to future reference of people with the same issue. It was my knock sensor. It was broken clean off.... probably from me pulling the tranny.
Old Dec 11, 2015 | 11:08 AM
Jaspah's Avatar
Yeah they break off pretty easy. Too bad they're so damn expensive
Old Dec 12, 2015 | 08:23 PM
uLmighty's Avatar
Have u ever had problems with ur boost controller using aemv2 ? I have an 08 and my temp gauge don't work neither lol. Sorry I thought I'd ask here instead of PM for further references also. Thanks if u can help
Old Dec 20, 2015 | 03:31 PM
nMeOnE's Avatar
I'm using a SC setup so no boost controller. Maybe someone else can chime in to help you.
I also don't have a temp gauge since I'm using a aftermarket dash with a direct signal input. From what I gather the V2 is suppose to display your temp gauge correctly
Old Dec 21, 2015 | 08:31 PM
liquidgsr's Avatar
I am using AEM V2 with MY07. Boost is controlled using a MAC solenoid. I don't think I had any issues with the temp sensor. I will chime in once I get back from tuning.
Old Dec 22, 2015 | 11:53 AM
uLmighty's Avatar
Please let me know! I'm tired of tryna figure it out lol. Does your VSA always show up? As far as I was told idle and low % percent are the ones that can't be fix with aemv2. I had my aemv2 looked at by aem and found "no issue." Maybe it has to do with my settings on my tune?
Mike's
May 14, 2018 05:32 PM
rmerchant3
Jan 19, 2017 07:47 AM
JayRSXS
May 27, 2015 01:19 AM
Phill24
Mar 12, 2012 03:15 PM
BSeriouS
Sep 18, 2007 12:43 PM
