06 Turbo Options
Here is your best bet the way I see it and it leaves much to be desired. I have 10K in my car and have only scratched the surface. Oh and the clutch will slip regardless of if you drop it or not. If you drop it you will likely shell the rear end or destroy axles. As far as good instructions and proven kits from my experience Inline has been very good, they are not the cheapest but you really do get what you pay for. For all those that built their own this is no issue but weekend warriors like me want a well engineered product to run with. From what I understand Inline will be able use many sizes of turbo's so if the t3/t4 is too small I am sure than can go bigger.
Oh, and this is no bolt-on, you will need to pull the head, transmission and modify many other parts to do this correctly. I you are talking about adding an intake, exhaust and a few small jobs as your experience you may want to seek assistance. I know the first time I pulled a motor I had no clue what I was doing and made a lot of mistakes I paid for later on.
From my experiance here is the absolute lowest to get near your mark with your qualifications.
Inline Pro Base $3500+
Inline Pro Accesories $1600
UGEO, BB Upgrade, HG, Injectors, Fuel Rail Adapter, I/J Clips, Map
Filter Relocation Kit $300
Hondata $1500+
Boost Controller $100+
Clutch $800+
MISC Fluids and parts $400
Professional Tunning $600+ (Tim Heron @ LS Honda)
Total $8,800
http://www.inlinepro.com/s2k.html
Scott
Hondata $1500+
Clutch $800+
Total $8,800
Scott
^All of that is if you install it all yourself, which you can't do. Especially the clutch unless you really know what you are doing. He also doesn't have exhaust/test pipe in there either which you are probably looking at another $800 at least.
I don't see anyway you can get out of getting a 500whp kit running correctly and safely for under 11-12 thousand.
and this would probably only put down 450WHPIf you were really skimping 9K might do it.
I got a quote from in-line pro for the full deal, installed out the door with-out an exhaust and gauges. It was over 10k with the S2k discount. It's a great kit and lots of room to grow. The Kraftworks is a good option for the newer cars as well. A used greddy kit or SC may be more in your budget. Also make sure to check with the tuner you want to use.
boostovereverything
Feb 13, 2012 01:50 PM
