!10psi Inlinepro Dynoed! Stock HeadGasket
Old Jul 26, 2006 | 06:01 AM
NO S8NT's Avatar
Originally Posted by CaptKirk,Jul 26 2006, 08:53 AM
I was thinking a cool 15 psi...
But then I'd probably have to get a clutch and I'm sure I'd need to upgrade my exhuast... as much as I don't want to
so ~$450-500 for tuning, ~$1,500 for the clutch installed, and ~$1,300 for the exhuast I want.
Kinda costly
Do it
Old Jul 26, 2006 | 06:10 AM
CaptKirk's Avatar
Originally Posted by NO S8NT,Jul 26 2006, 10:01 AM
Do it
You guys aren't helping..
Old Jul 26, 2006 | 06:39 AM
RobbieS2000's Avatar
PRS2K, any pictures of the set-up?
Old Jul 26, 2006 | 06:56 AM
PRS2K's Avatar
yes I will try and get pictures up today. Trying to figure out how to upload to my Comp from my digital camera.
Old Jul 26, 2006 | 10:36 AM
Spoolin's Avatar
Good numbers. Did you do it on pump gas? I am eventually going to bump the boost up to 10 psi on pump gas but was going to wait until I get my ARP headstuds on.
Do you think the stock headbolts will hold up and keep the head from lifting with that boost? I was worried in doing this with the stock headbolts and didn't want to score a cylinder.
Old Jul 26, 2006 | 11:45 AM
ya@inlinepro's Avatar
Spoolin,
contrary to what many believe, heads do not lift that easily if not, at all. I wouldn't worry about it if everything was installed correctly
TURN THE BOOST UP
Old Jul 26, 2006 | 12:24 PM
Scorpion's Avatar
I've been running 14psi for awhile now on a 2mm and stock bolts and have yet to have any lifting issues. I've also spiked up to 18psi quite a few times while I was messing with the boost solenoid
Old Jul 26, 2006 | 01:27 PM
Spoolin's Avatar
Originally Posted by ya@inlinepro,Jul 26 2006, 03:45 PM
Spoolin,
TURN THE BOOST UP
Well, the head has never been removed and the car only has 9500 original miles(boosted since around 3000) so I would assume it was installed correctly from the factory.
I'll try 10 psi on pump gas with the stock headbolts then and see what happens. From my calculations I will be around 18.5:1 total compression. Do you think that is safe on pump gas? What do you think the maximum overall total compression on pump should be that is safe? Before having to do any engine mods that is. I would also assume that around 18 degrees of timing will probably be about the highest I'll be able to go also.
Old Jul 26, 2006 | 02:32 PM
PRS2K's Avatar
[/IMG]
Old Jul 26, 2006 | 02:34 PM
PRS2K's Avatar
[/IMG]
