!10psi Inlinepro Dynoed! Stock HeadGasket
Old Jul 26, 2006 | 02:38 PM
  #21
PRS2K's Avatar
Here are some pictures of the Exhaust
Old Jul 26, 2006 | 03:28 PM
  #22
RobbieS2000's Avatar
Looks great man.
Old Jul 26, 2006 | 04:15 PM
  #23
PRS2K's Avatar
Just in case some of you were wondering the Nitrous System on the car was not used at the Dyno Inlinepro said it would not be safe to run 10psi and nitrous "On the stock HeadGasket" This picture shows the Nitrous switch setup. The top switch arms the entire system and also supplies power to the bottom switch which is the bottle heater. In other words the bottle heater will not turn on unless the system is going to be used. The red button beside the top switch is the Purge button. I was spraying a 50 shot on the car before I had the Turbo kit.
Old Jul 26, 2006 | 04:21 PM
  #24
PRS2K's Avatar
This picture shows were you have to notch the frame in order for the turbo to fit. I looked for a long time for this picture before I did my install and never found one so I made sure to take a picture of mine. The black you see around the hole was spray seal its just a spray you can by to seal exposed metal so it doesn't rust.
Old Jul 26, 2006 | 05:00 PM
  #25
Slows2k's Avatar
I'm not too wild about cutting into a frame rail to fit a turbo.
Wouldn't be done on my car.
Old Jul 26, 2006 | 06:01 PM
  #26
geists2k's Avatar
That's why I ordered my InlinePRO kit with a GT31R custom turbo. It's the largest turbo you can install without hacking into the frame like that.
Old Jul 26, 2006 | 06:05 PM
  #27
j_c_a's Avatar
eh, i did it. no big deal.
Old Jul 26, 2006 | 06:08 PM
  #28
Slows2k's Avatar
It's not as if the chassis of the car isn't too important
Old Jul 26, 2006 | 06:09 PM
  #29
Slows2k's Avatar
Old Jul 26, 2006 | 06:47 PM
  #30
Does the frame have to be cut with the supplied turbo as well? No boost for me if I have to cut the frame. That's what my shitty CRX would be for ???
