!10psi Inlinepro Dynoed! Stock HeadGasket
Old Jul 30, 2006 | 10:47 AM
  #61
BlownAP's Avatar
Originally Posted by Slows2k,Jul 26 2006, 05:00 PM
I'm not too wild about cutting into a frame rail to fit a turbo.
Wouldn't be done on my car.
that dosent affect the integrity of the fram under any type of flex??
Old Jul 30, 2006 | 11:45 AM
  #62
Raven628's Avatar
Originally Posted by Honda_mann,Jul 29 2006, 03:12 PM
get rid of that forsaken FRAM JUNK
blew the filter gasket one night and lost 2 quarts of oil in 20 seconds.
You don't want that problem.
Old Jul 31, 2006 | 12:04 AM
  #63
kane.s2k's Avatar
Nice numbers there
Old Jul 31, 2006 | 05:54 AM
  #64
Spoolin's Avatar
Originally Posted by PRS2K,Jul 28 2006, 05:16 PM
Are saying power starts to fall off because of not going into vtec? I looked at the graph and power is building the whole time. From what I remeber they said they set it so high because there was such a big dip at vtec and the only way to clear it up was setting it high. I sent Inlinepro a PM I hoping they will respond or post in here to clear up why they set it so high.
I will post the Dyno sheet Tonight when I get home.
Yeah, my power started to drop and we lowered VTEC a couiple hundred RPM to get the dip out. I have never seen the "low" cams make it much above 5800 rpm without starting to drop off.
Old Jul 31, 2006 | 08:43 AM
  #65
geists2k's Avatar
Originally Posted by timg,Jul 28 2006, 04:28 PM
What's the deal with the GT31R I've seen posted a few times? There's no such thing as a GT31R. At least not in Garrett's GT series lineup.
Tim
Just because it's not on Garrett's site it doesn't exist?
Read carefully:
http://forums.corvetteforum.com/showthread...06&forum_id=123
Old Jul 31, 2006 | 05:08 PM
  #66
dude01's Avatar
Originally Posted by CaptKirk,Jul 26 2006, 09:10 AM
You guys aren't helping..
Old Aug 1, 2006 | 05:16 AM
  #67
C45P312's Avatar
Nice
Old Aug 1, 2006 | 06:37 AM
  #68
Spoolin's Avatar
Just wondering if anyone at Inline is going to comment on these questions of mine from earlier the other day or not?
QUOTE (ya@inlinepro @ Jul 26 2006, 03:45 PM)
Spoolin,
contrary to what many believe, heads do not lift that easily if not, at all. I wouldn't worry about it if everything was installed correctly
TURN THE BOOST UP
Well, the head has never been removed and the car only has 9500 original miles(boosted since around 3000) so I would assume it was installed correctly from the factory.
I'll try 10 psi on pump gas with the stock headbolts then and see what happens. From my calculations I will be around 18.5:1 total compression. Do you think that is safe on pump gas? What do you think the maximum overall total compression on pump should be that is safe? Before having to do any engine mods that is. I would also assume that around 18 degrees of timing will probably be about the highest I'll be able to go also.
Old Aug 2, 2006 | 10:46 AM
  #69
ya@inlinepro's Avatar
Spoolin,
TURN THE BOOST UP
i thoguht i answered this in response to your PM?
Old Aug 2, 2006 | 01:16 PM
  #70
Spoolin's Avatar
You did and thanks. I wrote this before I thought to message you.
