10psi pulley VCS
Old Sep 3, 2006 | 01:04 PM
s2k_suprchrgd's Avatar
Default 10psi pulley VCS
i just installed my 10 psi pulley and it only reads 8.2 psi at 9100rpms on the AEM EMS
what you guys suggest? is there anything i need to do so it will reach 10 psi?
thanks
Old Sep 3, 2006 | 01:25 PM
Dsgs2k3's Avatar
do u have a aftercooler because it should read about .5 less boost. But if you have an EMS you can always raise the redline a little to get the full boost
Old Sep 3, 2006 | 02:39 PM
Slows2k's Avatar
Altitude and any cylinder head porting, CR change will effect the Max boost reading. Any other mods to the engine? What altitude do you live at? Is the belt tight?
Old Sep 3, 2006 | 03:22 PM
Dsgs2k3's Avatar
check the belt, check for any boost leaks
Old Sep 3, 2006 | 03:29 PM
Sideways's Avatar
This is why I recommend using pulley size rather than psi production when discussing and ordering pulleys. https://www.s2ki.com/forums/index.ph...pic=380286&hl=
Old Sep 3, 2006 | 05:29 PM
yes i have full port and polished head and fully built bottom end 9:1 CR
i live in chicago
maybe i should check the belt
Old Sep 3, 2006 | 05:31 PM
i'm sorry i forgot to mention my pulley size is 4.5"
Old Sep 3, 2006 | 06:00 PM
Slows2k's Avatar
A ported head and lowered CR will cause a lower boost # than a stock CR and stock head.
Time for a smaller pulley to get more boost with your 9:1 motor.
Old Sep 4, 2006 | 07:47 AM
John_Z's Avatar
I'm running a 4.4in pulley and hit 10psi at 9000rpm:
Old Sep 4, 2006 | 08:02 AM
Sideways's Avatar
Basic question, what supercharger did you install?
