10psi pulley VCS
Old Sep 4, 2006 | 12:36 PM
s2k_suprchrgd's Avatar
Originally Posted by Sideways,Sep 4 2006, 08:02 AM
Basic question, what supercharger did you install?
i have the vortech unit
Old Sep 4, 2006 | 12:40 PM
Sideways's Avatar
Originally Posted by s2k_suprchrgd,Sep 3 2006, 02:04 PM
i just installed my 10 psi pulley and it only reads 8.2 psi at 9100rpms on the AEM EMS
what you guys suggest? is there anything i need to do so it will reach 10 psi?
thanks
The problem is the 4-1/2 inch pulley is a 9 lb pulley and not a 10. Get a smaller pulley.
Old Sep 4, 2006 | 12:42 PM
Originally Posted by Slows2k,Sep 3 2006, 06:00 PM
A ported head and lowered CR will cause a lower boost # than a stock CR and stock head.
Time for a smaller pulley to get more boost with your 9:1 motor.
so in order for me to run 14psi pulley i will need smaller than 3.8" pulley?
Old Sep 4, 2006 | 12:52 PM
i just checked the pulley chart list and it states 4.5"pulley = 10psi at 9000rpm
my redline is at 9500 so the extra rpms should make more boost?
Old Sep 4, 2006 | 01:51 PM
Sideways's Avatar
I made the chart and pulled the numbers out of the air.
What ever you have is what you get. Order up several and have fun. The 4.25 inch would be fun. The 4 inch would be even more fun,
I've been seeing high 13s to low 14s with the 4 inch at 9200 rpm.
Old Sep 4, 2006 | 02:05 PM
Slows2k's Avatar
The issue is you can't compare pulley diameter with Psi produced. You car now makes approx 1.8 psi less than a stock motor. So find a pulley diameter that makes about 1.8psi more than what you want on a stocker.
On a 9:1 motor I'd be wanting a 4" pulley or smaller.
s2kseven
Jun 13, 2019 11:17 AM
s2konroids
Apr 11, 2012 03:51 AM
Sideways
Sep 25, 2007 09:37 AM
faukengenius
Aug 21, 2007 07:26 AM
abv
Feb 11, 2007 03:10 PM
