11 or 12lb pulley?
Old Aug 10, 2009 | 10:06 PM
s2000Junky's Avatar
Originally Posted by RAIN H8R,Aug 10 2009, 09:55 PM
yeah Id like to know who makes that...I no not kno the efficiency of the blower other than other people/users "saying" it peaks at 14/15psi.
Id like proof behind this theory...
Yeah, there has been some past threads on the subject. I know the VT/CT blowers are suppose to max in the range of 50,000/55,000rpm but i don't know the exact or where that relates to pulley size. And if its over spun what does the blower do, implode? They do make a higher cost ceramic bearing replacement set for the CT/paxton blowers to help combat the added heat that takes place with the added blower speed.
Old Aug 11, 2009 | 11:14 AM
chillout18's Avatar
Well by the responses I'm going to do the 12lb pulley Injectors I'm going to educate myself a bit more and see what will work.
thanks everyone for the suggestions
Old Aug 11, 2009 | 06:31 PM
camuman's Avatar
good. 12psi pulley and ID 725injectors + emu + fmic.
/thread
Old Aug 11, 2009 | 08:33 PM
s2000Junky's Avatar
Old Aug 11, 2009 | 09:05 PM
RAIN H8R's Avatar
not related to the thread, but I got beat tonight by a C6 base model Corvette. So now Im swapping out my 70mm test pipe for a 63mm. Obtaining a CR catback for free (straight through mufflers vs my AP1 twin loops), ill be deleting the resonators on the catback, purchasing a 3.0in pulley and getting it retuned at King.
What do you think?
Old Aug 11, 2009 | 09:54 PM
s2000Junky's Avatar
[QUOTE=RAIN H8R,Aug 11 2009, 09:05 PM] not related to the thread, but I got beat tonight by a C6 base model Corvette.
Old Aug 12, 2009 | 04:38 AM
RAIN H8R's Avatar
Thats very impressive. On 8.6psi (what the 2bar map sensor read) I was putting down 323/202 in marhc with a 70mm headerback with Invidia V3. Now I have a 70mm test pipe with stock exhaust putting down 319/191. However, my gauge reads 10psi at redline with my 12# 3.2inch pulley.
I dont think a smaller pulley is really the answer, I know ill see better gains with a better flowing exhaust, buts its just not in the cards right now. Im on a super tight budget with trying to buy a house within the next year.
Old Aug 12, 2009 | 08:31 AM
s2000Junky's Avatar
There is quite a few variables and not always the typical when thinking what is supose to work.
A little more about my configuration.
3.6 sos pulley/10psi at 9K rpm with f22
stock header/60mm tp and tanabe dual cat back
8lb flywheel
stock ecu/injectors/ adjustable rate fpr
Water/meth injection
Old Aug 12, 2009 | 08:51 AM
RAIN H8R's Avatar
wait your on a FPR? How on earth are you not leaning out? Especially with the stock injectors. Your setup is not a "common" way of doing it, but kudos to you for pulling it off
Old Aug 12, 2009 | 08:59 AM
s2000Junky's Avatar
3 words, water- meth- injection No its not common at all. But it works well. Could it be improved upon? Definitely and it will continue to evolve somewhat, but so can 90% of the set ups out there. I commute 100miles a day in this car and went through several sessions at the track on Monday. Its effective you could say
