2.4L stroker or 2.0 Built help me decide
Originally Posted by Irishflame27' timestamp='1346985900' post='21993982
tell InlinePro you are an s2ki member and you will get a discount! But i agree a stock motor is more than fine for your goals
Originally Posted by anarchy187' timestamp='1346988974' post='21994055
[quote name='Irishflame27' timestamp='1346985900' post='21993982']
[/quote]
Good idea, but I cant find a good 2.2 crank.
Make sure you get arp head studs that's the #1 must, it's upto you but I'd pick up some ferrea springs and retainers and thats mostly it. Idk what shape this block is in or how many miles are on it but you can do oil pump, tct, oil chain tensioner, all the guides many will say you dont need it but when I built my motor I spent the extra 500 bucks on these things to protect a 4k shortblock. Just food for thought
-chris
-chris
From the factory, what I understand is not all bearing surfaces and bearings are the same size. What matters is if there is enough area after polishing the crank surfaces to accommodate a off the shelf bearing with proper clearances. Have you talked directly with any Honda engine builders?
then its 2.4 land for me.
^torque for sure but that's not necessarily true for hp since you can rev these 2.0s out further and when running a decent size turbo it makes the majority of its power uptop. Just putting in my .02
