2000 S2000 Turbo.
Old Oct 23, 2007 | 04:41 PM
bassamdp's Avatar
Default 2000 S2000 Turbo.
Hey guys. recently turbo'd my S2K, and I plan on doing my second oil change.
I may drive my car in the winter (MAYBE on a nice day).
Below are my mods, I'm looking for some feedback on what oil to use and why...
(I tried using the search box, but kept getting an error. Help and comments would be appreciated).
ENGINE MODS ONLY:
MOTOR:
- Garrett custom spec t3/t04E turbocharger
- 2.5 downpipe
- fabricated tubular Steel turbo manifold (w/ polished heat shield)
- TiAL 38mm external wastegate
- Stainless Steel Wastegate Dump Pipe
- Large bar and plate front mount intercooler
- 2.5" stainless steel intercooler piping
- HKS super sequential blow off valve
- 3" polished intake pipe with K&N air filter
- RC 550cc fuel injectors
- AEM fuel pressure regulator
- Cat-less cat (essentially a test pipe, but looks like a cat!)
- Ultimate Racing 3" dual exhaust system
ELECTRONICS:
- AEM EMS standalone ECU (tuned at xxxhp!)
- AEM single channel wideband O2 sensor (UEGO)
- SPA technique dual EGT/boost gauge
- Autometer Air/Fuel ratio gauge.
TRANSMISSION:
- Spoon clutch (street)
- Spoon clutch cover
- Spoon release bearing
- Spoon flywheel
Old Oct 23, 2007 | 04:59 PM
Soul Coughing's Avatar
i have the exact same setup as you
Depending on how cold it gets around your parts, either run 5w-30 or 10w-30... i personally run mobil 1 and just sent out my oil to be analyzed... i will give updates when it gets processed
Old Oct 24, 2007 | 09:03 AM
bassamdp's Avatar
Interesting...'analyzed'??? ....meaning?
Thanks.
Old Oct 24, 2007 | 09:32 AM
oil analysis, it looks at the oil and tells me what is in the oil... copper anti freeze etc... and i paid for the extra option that gives me an analysis of how long the oil will last etc...
Old Oct 24, 2007 | 01:46 PM
jwa4378's Avatar
I believe there is a whole section called the "oil journals" in the UTH stickie section.... not sure if it touches on FI or not, but it does breakdown what oils are better for cold whether.
John
Corey Maurer
May 16, 2011 05:19 AM
superslows2k
Nov 11, 2009 06:45 AM
superslows2k
Bay Area For Sale
Sep 18, 2009 08:45 AM
superslows2k
Sep 18, 2009 08:36 AM
bassamdp
Mar 21, 2009 03:23 PM
