2008 SOS SC'ed S2000
Old Jun 19, 2011 | 11:36 AM
  #21
donaldmejr's Avatar
Originally Posted by s4play
Originally Posted by donaldmejr' timestamp='1308426010' post='20696221
[quote name='camuman' timestamp='1308425862' post='20696214']
[quote name='donaldmejr' timestamp='1308425513' post='20696202']
[quote name='akirhol' timestamp='1308419504' post='20696038']
Awesome numbers, awesome build... considered going E85?
I am...race fuel isn't cheap
I'd 2000 inectors an maybe a kbap and ur set. Possibly just the injectors and more fuel pressure.
[/quote]
yep inlinepro return kit with a 340 pump
[/quote]
Does this kit make a big difference over a simple in-tank pump like the Walbro? Is there any negative to upgrading to this type of fuel delivery system?
[/quote]
i was told its required over 400whp
Old Jun 19, 2011 | 12:23 PM
  #22
DFWs2k's Avatar
dbw guys don't need to upgrade to return style till over 450whp
Old Jun 19, 2011 | 02:52 PM
  #23
donaldmejr's Avatar
I knew it was around that range...
Well it appears that I may have spark blow out. I removed my heat range 8's spark plugs and replacd them with 9's. I took the car around the block today and I took it up to 8K and when I shifted gear and got back into it nothing happened when I pressed on the gas. I let off shifted up and then everything was fine. This happened to me twice. I measured the 9 plugs before installing them and they apeared to be gapped at .30". I noticed when I plugged into flashpro I had a DTC for 1 & 4 misfires. I regapped the plugs down to .22" and swapped coils #1 with #2 and #4 with #3. I haven't driven the car since.
Any thoughts from anyone?
Old Jun 19, 2011 | 09:07 PM
  #24
Deception's Avatar
any chance you have boost graph for the 19psi tune? interested to see how much boost you make at any given rpm
Old Jun 19, 2011 | 09:26 PM
  #25
donaldmejr's Avatar
no I didn't get one from Evans Tuning. I will do a few datalogs tomorrow since I have to see if im still having spark issues
Old Jun 23, 2011 | 05:24 PM
  #26
donaldmejr's Avatar
THANKS EVAN!!! I've been meaning to scan mine.
blixhavn
Jun 27, 2011 04:30 PM
donaldmejr
Jun 24, 2011 03:38 PM
pinstriped06
May 12, 2009 05:50 PM
donaldmejr
15
Apr 5, 2009 12:56 PM
shadowz
Nov 15, 2008 09:46 AM
