Supra Tranny
Old Aug 26, 2010 | 03:39 PM
m R g S r's Avatar
Default Supra Tranny
Just curious, wanted to start a discussion thread about supra trannys.
Getrag 6 speed
Cost invloved:
Custom adapter plate
Custom Driveshaft
Custom clutch (twin disk most likely)
Custom mount
Custom shifter
New or Used supra tranny
possible modification of opening in tranny tunnel for shifter
This setup should be able to hold all the power (and lack of TQ lol) that an f20/f22 can make, and be launched without failure.
I feel this is a much better solution to the PPG gear set (which has already broken on a few members, no warranty remember), and it's honestly not that much more $.
This also doesn't restrict the car to strictly drag, the way some guys have done by going with an automatic tranny.
NEW price of tranny, cheaper than PPG gear set
http://enjukuracing.com/toyota-getrag-6spe...ion-p-8488.html
Used they are around $4kish
Old Aug 26, 2010 | 03:55 PM
spectacle's Avatar
By the time you spend all that money, you could have just bought a Poopra and been 10x ahead
Old Aug 26, 2010 | 04:19 PM
m R g S r's Avatar
i know that thats why im selling my car.
but think about breaking ap1 or ap2 trannys and all the time and $ wasted on fixing them just to be back at square one, not knowing if your tranny will break every time you hit the gas.
this is a semi affordable solution to a bulletproof drivetrain.
Old Aug 26, 2010 | 05:40 PM
godmachine's Avatar
Those trannys are expensive. Time it would take custom fabbing stuff for the install im sure you could of had 8 stock trannys or swapped in a gforce 5 speed
Old Aug 26, 2010 | 05:49 PM
Spoolin's Avatar
How about a Tremec T56 6 speed trans? The shifter placement looks more inline with the OEM trans and it even looks similar to the OEM trans.
http://www.bigfastcar.com/transmissions.asp
If I'm not mistaken, the shifter placement can also be adjusted with this trans.
Old Aug 26, 2010 | 05:53 PM
godmachine's Avatar
I dont believe the t56 can take high rpm shifts well. This is the reason you want to use the t5 swap
Old Aug 26, 2010 | 06:01 PM
Spoolin's Avatar
How about the TR6060 then?
Old Aug 26, 2010 | 06:18 PM
godmachine's Avatar
I dont know . It would be larger than a t56 is a concern , but It might make good on shifter placement . Someone buy one and see if it can take a 9k shift and let us know lol
Old Aug 26, 2010 | 07:14 PM
siadam's Avatar
My buddies tremec has an adjustable shifter point in his mustang.
It's a 427 (7L) and makes 700whp on a 200 shot.
It seems to hold the tq, and is FAR beyond what we would ever see.
Even at 1000whp we wouldn't be near 700wtq, lol.
Old Aug 26, 2010 | 07:50 PM
s2k dre's Avatar
