2JZ S2000... FeedBack Needed
Old Dec 16, 2011 | 09:56 PM
StocS2k's Avatar
Default 2JZ S2000... FeedBack Needed
I just love seening these swap.
http://youtu.be/wJOJdagbHK0
In all honestly I wonder what it really takes.
Engine and r154-Cake
Mounts- Not a big issue Fits in stock mounts I believe. I talked the Ad_turbo about that a Wildd back.
Custom Driveshaft-Nothing big
Remove center crossmember- Nothing big
Shifter and trans fit in same spot stock is. Believe it or not.
Custom Wiring harness... A little work
AEM EMS- Vendor Bitch
Let me know Guys I wants some honest feedback.
Old Dec 16, 2011 | 10:04 PM
miguel329's Avatar
Honest feedback turbo s2 engine save rest money... Lol but i thought shifter didnt sit rite, been few yrs since ive read on any of those swaps so not 100% sure on that
Old Dec 16, 2011 | 11:18 PM
9krevvin's Avatar
How much power are you looking to make? In my honest opinion I would not do it unless you are looking to make 1000 whp+. If you are, you are going to need the v160 transmission not the R154. The 2jz-gte engine is heavier than the f20/22. The only benefit I could see to the 2j swap would be more torque (which the s2000 differential can't handle) Why not do a Sidewinder manifold on a 6262 (or bigger) with a v160 transmission swap and a Ford 8.8 Differential? It has been proven by many people on here that with an efficient turbo setup the F20/22 can make great power boosted,While still being reliable. There are most likely many things you are not considering as well. Your electronic power steering, Air conditioning, Upgrading the 2jz after buying....etc. If you buy the engine and just drop it in you will lose power over your current setup. It will cost quite a bit to modify the new engine. (Turbo, Manifold, & injectors) Just my opinion not trying to be rude, I hope this helps your decision.
Old Dec 17, 2011 | 12:05 AM
s2000Junky's Avatar
Its more of a talking piece it seems to me, rather then a practical application. If you need the extra trq, then your going to need to upgrade the rest of your drivetrain parts, if your willing to do that, then you can get to the ground. Practically speaking, our engine is more then capable for anything you want to do with it. 2Jz swap is a cool talking piece though, I have always liked inline 6's
Old Dec 17, 2011 | 07:35 AM
camuman's Avatar
Stock s2k motor + side winder mani + big turbo + e85 + v160 + ford 8.8 = wet dream.
Old Dec 18, 2011 | 10:38 AM
buzz944's Avatar
I've been considering a 2JZ or LS1 swap as well since my motor is blown. IMO an LS1 or LS3 swap is better and I'm not sure but I think it's lighter also
lets just hope i can resleeve my block cuz i really don't wanna ruin her.
Old Dec 18, 2011 | 01:11 PM
Deception's Avatar
I say LS swap, big HP & torque without needing FI = win!
Old Dec 18, 2011 | 05:05 PM
vbb's Avatar
vbb
I want a 2JZ swap... but I want to put it in a '72 Datsun.
Old Dec 19, 2011 | 04:51 AM
InductionPerformance's Avatar
What are your goals? Being you want to use an R154 I would say not very high. In that case I would stick to the stock engine. It's pretty strong. The only thing the 2JZ will get you is a little more attention.
Old Dec 19, 2011 | 05:30 AM
Corey Maurer's Avatar
Honda motor FTW
