3.2" Comptech Supercharged S2000 (Dyno)
Old Apr 13, 2013 | 11:29 AM
  #51
KaNgArOo's Avatar
Yep. I'm seeing a little over 12psi right now. I can't wait to finally have my car finish. Tired of spending money and time to get everything sorted out. I just wsnt to drive!
Old Apr 14, 2013 | 08:47 AM
  #52
KaNgArOo's Avatar
VIDEO Posted. 330ish whp pull. On the first page.
Old Apr 14, 2013 | 05:57 PM
  #53
OkiDan's Avatar
Looks solid man, happy you got your tune straightened out. What do you guys think about running a 3" pulley on a 2.2l?! I have a 3.6" pulley was gonna set my system up in power. And with this being motor #2 I'm worried about adding too my h boost an POP. With the 3" will I see 12 or 15lbs of boost. I called SOS and they told me the 3" pulley on the Novi1K on a 2.2l can be anywhere from 12psi to 15. I would be ok with 12lbs, but I think 15lbs would be too much without a head gasket. ?
Old Apr 14, 2013 | 07:13 PM
  #54
That Guy 1987's Avatar
Dude some reading about aftermarket headgaskets. They're not needed!
OP how much boost are you making at 330whp?
Old Apr 14, 2013 | 07:39 PM
  #55
KaNgArOo's Avatar
Making 12psi on all the dyno runs. Going back for a fibal tune and 3" single sometime this week. Will update when I do.
Old Apr 14, 2013 | 08:32 PM
  #56
Moddiction's Avatar
Former Sponsor
Something's certainly wrong. Hopefully the tuner can figure it out.
Old Apr 14, 2013 | 08:41 PM
  #57
s2000Junky's Avatar
With stock 2.2 rev limit I averaged 14psi. Fine for the stock motor. Personally I would raise the rev limit to 8500 and tap out the blower speed and efficiency range of the motor. That added rpm will net you about 15psi. With a proper tune, you can reliably run on that for many many miles. Should get you at or just over 400whp/260trq dynojet.
Old Apr 14, 2013 | 09:09 PM
  #58
liquid_helix136's Avatar
The 330whp plot you posted looks like your only hitting ~10psi. Also I think the timing needs to be adjusted for your lower vtec. I think thats why that dip is there, when vtec engages the timing needs to be advanced a good bit more than on the lower cam profile.
Old Apr 14, 2013 | 09:19 PM
  #59
Sorry bud but with what everyone just said this I think is the root of your problem. Putting my smaller pulley on this Wednesday hope to be tune by mase Saturday. If I make the same or more power on 9lbs then you know the issue with yours. I will have stock exhaust as well. For the amout of boost that you made 330whp still isn't close to what it should be. As mod posted his numbers with same boost but 100whp more.
Old Apr 14, 2013 | 09:41 PM
  #60
s2000Junky's Avatar
350whp is the average for 10psi on the comptech kit.
