3-4K hesitation with V-2?
Old Oct 15, 2015 | 05:29 AM
TraxxofAOT's Avatar
Default 3-4K hesitation with V-2?
I got a 02 with a Vorteh V-2 sq and in the past weeks everyone once an a while during cruising I get what I can only describe as a hiccup between 3-4K RPMS. It's only done it once in a full throttle situation. Every time I've taken it in, it never does it with the Mech in the car. Any starting advice would be great!
Old Oct 15, 2015 | 08:44 AM
hvAlfaWant_S2000's Avatar
Are you slightly pressing the gas as the revs move higher, and then when you press the gas a little more, it stutters???
Old Oct 15, 2015 | 01:36 PM
TraxxofAOT's Avatar
Yea, seems like it,
Old Oct 15, 2015 | 03:59 PM
What fuel pump and injectors are you running?
I was running Bosch 1000cc injectors w/ a FB340 pump and I would get that scenario, as I described in my previous post.
I demonstrated this to my previous tuner, and he said "well, don't drive it like that". So, when I drove it, I pushed the pedal down and boogied!!
If you get on the gas, do you get the same hesitation at 3-4k rpm?
Old Oct 15, 2015 | 08:52 PM
TraxxofAOT's Avatar
Sometimes, I have stock injectors and I am not sure about the pump, it may have come in the Vortech kit along with the FMU, I bought the car like this
Old Oct 16, 2015 | 02:38 AM
Hmmm, you running a AFR guage? What numbers are you seeing?
If you can't see numbers, then maybe time to see a reputable tuner.
Old Oct 16, 2015 | 08:32 AM
TraxxofAOT's Avatar
What can a tuner do to the kit? I thought you can't tweak and tune the Vortech kit and stock ECM? And yea, I have no gauges for any of that except the wireless OBD2 sensor
Old Oct 16, 2015 | 01:35 PM
s2000Junky's Avatar
It could be a fueling issue. And you can't verify this without an on board wideband gauge. This along with a boost gauge is basic necessary stuff when going FI for troubleshooting as well as tuning. The VT fuel regulator that comes with the kit has no external fuel calibration adjustment unlike the comptech unit, however it can be modified by adding pre load pucks inside to add or subtract fuel. Its archaic but an option. If you plan on sticking with this base level boost indefinitely, id at least ditch it and go with a comptech unit so you can easily adjust it.
Also very likely, the VT black box which hides boost from the ecu can be unreliable. The old splice in ESM comptech used worked super reliable, and the next Gen in the SOS and ct kits are now pnp and actually control vtec and fueling along with the map voltage so its a reliable upgrade to the base psi kits. I would consider ditching the vt black box and getting one of these units as well. At 3-4k rpm and mid throttle is the vac/boost threshold and if thats where you are experiencing a hiccup, this is the likely device that isn't doing its job. It can and should be butter smooth through all throttle positions. Dont settle for less.
Old Oct 16, 2015 | 08:23 PM
TraxxofAOT's Avatar
Hmmm
Akkmednoseflem
Dec 17, 2017 02:13 PM
lude9285
May 3, 2016 01:23 PM
riceball777
Jun 16, 2015 10:37 AM
urban.gentlemen
Oct 27, 2012 08:00 PM
jpetch05
Mar 20, 2012 09:14 AM
