38mm Tial WG
Old Apr 24, 2008 | 09:49 AM
Shftat9k's Avatar
Default 38mm Tial WG
Well I will be turning up the boost on my car for this summer. I have a 38mm Tial wastegate with a 6psi spring. How much boost can this spring hold steadily?
I plan to run around 18psi. If needed what size spring would you recomend?
Thanks
Martin
Old Apr 24, 2008 | 10:10 AM
ya@inlinepro's Avatar
Generally rule of thumb is you can double the spring rate. So about 12psi is what would be "steady"
Old Apr 24, 2008 | 10:15 AM
btstone84's Avatar
doesnt that depend on the tune Ya? becasue dont you guys have my spring rate more than double?
Old Apr 24, 2008 | 10:17 AM
AndyFloyd's Avatar
I ran a 38mm on my miata, it had a 6.5psi spring and would hold 18psi all day long.
Old Apr 24, 2008 | 10:43 AM
Spoolin's Avatar
I've always heard the same about not going over double psi from what the spring rate is because boost could become unstable, but I am running 25-26 psi on my 10.15 psi spring and boost is holding pretty steady. I plan on adding my old 5.8 psi spring to see if anything changes.
The only problem I have noticed is my 60-1 turbo holding boost at 26 psi or above. I think I've hit it's limit and it's getting into compressor surge territory.
Old Apr 24, 2008 | 01:44 PM
AndyFloyd's Avatar
yeah the 60-1 is an older compressor and i think it tops out around 25-26psi. I bet you are right at the edge of the compressor map on it. Hey, plus you still owe me a ride.
Old Apr 25, 2008 | 05:36 AM
Spoolin's Avatar
If you ever get the chance, I'll be out at HL most Saturdays or where ever Blevins and I end up. I still haven't gotten it out yet this year but may be out if it doesn't rain.
1SlowSi
May 10, 2012 07:13 AM
1SlowSi
Feb 17, 2012 05:09 PM
JuicedS2K
Jun 21, 2010 07:31 PM
markeymark13
Dec 10, 2009 09:00 PM
