400 hp
Old Sep 16, 2009 | 11:07 AM
  #61
CourageOO7's Avatar
Originally Posted by 518135,Sep 16 2009, 01:43 PM
Its a good idea do have a built motor! Most of the guys dont build them but they are pushing the limits big time. Its kinda risky if you ask me.
There's really 2 schools of thought on this. Some guys with more aggressive SC setups than I have the guts for, have had success pushing the limits of dead stock F20C/F22C's for many miles.
As of late, the real debate is on the stock HG vs the 3mm HG (costs/benefits of both).
But yeah, if you're due for a new motor/rebuild...might as well build one up the way you like it.
Old Sep 16, 2009 | 11:52 AM
  #62
John_Z's Avatar
Originally Posted by EnVme,Sep 16 2009, 10:12 AM
I see most of the s/c setup over 400hp have there motor built. Do you need your motor built for a s/c making over 400hp? cause I see a lot of turbo setup over 400hp with stock motor is there a differance?
You don't need a built motor as long as you have a reliable tune. If you want to play it safe lower the compression via a headgasket or pistons. I personally run a stock bottom end, 2mm HG, and a built head pushing 15.7psi with zero issues.
Old Sep 16, 2009 | 12:31 PM
  #63
CourageOO7's Avatar
From the horses mouth!
Old Sep 16, 2009 | 03:44 PM
  #64
juntuned's Avatar
Can you think of ANY reason to lower compression with a SC setup under 16psi?
Man I hate lower compression.
Old Sep 16, 2009 | 05:29 PM
  #65
RAIN H8R's Avatar
your pushing 499 with a stock bottom end?
Old Sep 16, 2009 | 05:52 PM
  #66
John_Z's Avatar
Yes
Old Sep 16, 2009 | 06:51 PM
  #67
s2000Junky's Avatar
Not really. Your making boost progressively with an SC rather then all of it at a lower rpm like turbo and then flat lining, so in other words less circumstance of detonation for SC. And nothing that some timing retard or water/meth kit couldn't handle. I'd keep your stock compression and just make sure your tuner isn't back woods
Old Sep 16, 2009 | 06:54 PM
  #68
s2000Junky's Avatar
Man that sucks, to come all this way to be one hp short of 500.
Stock internals FTW
Old Sep 16, 2009 | 07:04 PM
  #69
John_Z's Avatar
Stock internals FTW
Actually, when it's less than 86* ambient I make 500+
Old Sep 16, 2009 | 07:26 PM
  #70
RAIN H8R's Avatar
So, how long have you been running your car like that? Miles/years/hours/minutes....?
