44mm wastegate flange size?
Old Sep 20, 2013 | 09:22 PM
equ117's Avatar
Default 44mm wastegate flange size?
Alright guys need a little help. Quick question/confirmation. 2 1/2" is a flange that of a 60mm wastegate correct???? Also dump tube flange measures 2 1/4". I had ordered my manifold & dump tube combo to be fitted with 44mm wastegate. This is what I received....
Wastegate flange that is on the manifold...2 1/2"
Wastegate flange that is on the dump tube...2 1/4"
All dimensions pull off of Tials website...
Tial 44mm wastegate dimensions: Inlet Flange: 1.875" OD Outlet Flange: 1.75" OD
Tial 60mm wastegate dimensions: Inlet Flange: 2.5" OD, Outlet Flange: 2.375" OD
Old Sep 20, 2013 | 11:22 PM
riceball777's Avatar
If your dump tube is over 2 inches than its for a 60mm gate. A 38mm wastegates uses a 1.5 inch dump tube. A tial 44mm uses a 1.75 dump tube.
Old Sep 20, 2013 | 11:38 PM
equ117's Avatar
I just measured the diameter of the dump to tube itself. It is 1.75".
Old Sep 21, 2013 | 09:11 AM
Then your setup is for a tial 44mm.
Old Sep 21, 2013 | 10:24 AM
5thgen's Avatar
http://www.tialsport.com/documents/MVR_Tech.PDF
This is for a MVR gate (44mm), but it shows roughly the same measurements on the OD of the vband flanges.
A tial 60 shows rougly 2.50 / 2.25 inner diameter.
Old Sep 21, 2013 | 03:09 PM
equ117's Avatar
Originally Posted by equ117' timestamp='1379749095' post='22789389
[quote name='riceball777' timestamp='1379748126' post='22789384']If your dump tube is over 2 inches than its for a 60mm gate. A 38mm wastegates uses a 1.5 inch dump tube. A tial 44mm uses a 1.75 dump tube.
[/quote]
Originally Posted by 5thgen
http://www.tialsport.com/documents/MVR_Tech.PDFThis is for a MVR gate (44mm), but it shows roughly the same measurements on the OD of the vband flanges. A tial 60 shows rougly 2.50 / 2.25 inner diameter.
Ahhh good find!!! Wish i found that earlier. Well that settles that lol thanks for the help guys I appreciate it!
S2K-OED
May 16, 2016 07:27 PM
GoOn3
May 29, 2012 06:35 PM
B5254T4
Mar 7, 2011 07:56 AM
skool u
Aug 3, 2010 02:19 PM
