550 cc injectors on stock computer
Absolutely not! It will run like crap and most likely tank your motor from fuel wash. If its a stock vortech kit, keep your OEM injectors and tweak the FMU as needed to get your AFRs to atleast 12.5 and preferably lower, like maybe 11.5-12 and be sure to use a 1 step colder resistor spark plug.
If you want to upgrade, get a stand alone ECU because piggys are a PITA and trust me, you will want the flexibility of a stand alone in the future.
Do not run the 550s with the OEM ECU.
Im gonna back pedal here some, what MY are you? If you are 06+ Then you can get FlashPro and then running the injectors would be as simple as a relfash from your tuner.
gusrock77
Sep 8, 2009 08:49 AM
