550 cc injectors on stock computer
Old Sep 6, 2012 | 10:08 AM
SickoS2K's Avatar
Default 550 cc injectors on stock computer
hey just wondering if 550 rc injectors will run ok on my stock computer. IM running a vortech supercharger and a timing and map box with fmu.
Old Sep 6, 2012 | 12:18 PM
Kyushin's Avatar
Banned
Absolutely not! It will run like crap and most likely tank your motor from fuel wash. If its a stock vortech kit, keep your OEM injectors and tweak the FMU as needed to get your AFRs to atleast 12.5 and preferably lower, like maybe 11.5-12 and be sure to use a 1 step colder resistor spark plug.
If you want to upgrade, get a stand alone ECU because piggys are a PITA and trust me, you will want the flexibility of a stand alone in the future.
Do not run the 550s with the OEM ECU.
Im gonna back pedal here some, what MY are you? If you are 06+ Then you can get FlashPro and then running the injectors would be as simple as a relfash from your tuner.
Old Sep 6, 2012 | 01:55 PM
SickoS2K's Avatar
Ok sweet thats all i wanted to know.. I have an ap1 and its running on 10-1 fmu might have to go a bit higher its running at 10 afr at 3 psi and climbs to about 13 at 7psi.
Buzz2K
20
Sep 27, 2012 01:37 PM
gusrock77
Sep 8, 2009 08:49 AM
s2000Junky
Sep 23, 2008 01:07 PM
SCvortech
Feb 17, 2005 07:39 AM
frans2k
Jun 16, 2004 05:32 AM
