Is -6 AN fuel line too large w/ Turbo?
I'm in the process of relocating my SX FPR feeding a Spugen Turbo and I erroneously purchased -6 AN fuel line. In looking at the parts that came w/ the kit, it appears to be -4 AN line. Are there any drawbacks to installing the -6AN line that I purchased, or should I just return it for -4 AN? It seems to me that the larger fuel line won't hurt since the flow will be controlled by the injectors anyways, but I'd definitely like some other opinions. By the way, the kit will be running about 7psi and the fuel pump is stock. Injectors are 550cc. Thanks for any help you all can give--
I thought you only needed an upgraded pump if you're planning on bigger boost w/ bigger injectors (750cc and up)? I could've sworn that many on here have said that 7 psi w/ an FPR is definitely sufficient, which is why all the kits come w/ an FPR rather than an upgraded pump?
Originally Posted by Wahooz,May 25 2007, 09:16 PM
Ok, thanks....so when I upgrade to a walbro 255, will I still need the SX FPR?
BoostAlong
02-08-2017 02:41 PM
Chance S2K
05-14-2015 07:16 AM
