600+ hp ?
Old Mar 27, 2006 | 11:13 AM
  #31
blues2k3's Avatar
anything over 18psi would be not too safe on pump. The higher octane levels will not only allow you to tune more agressively but will also prevent detonation. The higher octane rating will resist combustion from all that compression....
Old Mar 27, 2006 | 12:39 PM
  #32
Gink5's Avatar
I'm a FI novice so take it for what its worth. It seem to me you are trying to keep up with cars that run (for reference) 11-12 second 1/4 miles. I dont think you would need to put down 600 hp to do that. You may be just as succesful and more realiable going a little less agressive.
Old Mar 27, 2006 | 01:17 PM
  #33
blues2k3's Avatar
not at all, we ran 10.6 at just 490 at the wheels on a street tire. Running 11s you would need 400 range.
Old Mar 27, 2006 | 02:15 PM
  #34
FF2Skip's Avatar
Is this for turbos only as they reach max boost for long periods per gear? I'm at 1.4 BAR with my CTSC... obviously peak boost.
Old Mar 27, 2006 | 02:21 PM
  #35
AusS2000's Avatar
Certainly applies more to turbos for that reason, but it's still applicable to SCs.
But then it's a matter of tuning. If you're running well without knock as you are then ok. You may find though that the tuner pulled more timing to accommodate the boost and pump gas however.
Old Mar 27, 2006 | 02:44 PM
  #36
FF2Skip's Avatar
Thanks, Aus.
Old Apr 30, 2006 | 01:33 PM
  #37
Mr. Tom's Avatar
Originally Posted by fperra,Mar 25 2006, 10:29 AM
Actually, that's about what I'm running on 93 octane.
You wanna send some of that 93 octane west?
Spaceentity
Feb 19, 2014 08:58 AM
passmans2kny
Aug 31, 2012 06:28 PM
Julio Acevedo
Jan 13, 2006 10:26 PM
kjs2000
Nov 13, 2005 08:53 AM
camerons2000
Feb 13, 2003 02:57 AM
