6mm
Old Mar 28, 2010 | 02:50 PM
AusS2000's Avatar
Default 6mm
I had a 3" single exhaust with a cheap muffler made when I went turbo. It was at the end of the process and funds were a little tight so nothing special.
But damn is it loud. Obnoxious is the best word for it.
The plan has always been to replace the back end with a split and twin mufflers but so far I haven't got around to it.
I have the chance to pick up an Invidia 70mm twin system. Not only that but the previous owner replaced the front resonator with a bigger Lukey unit to reduce the sound.
Will going from a 3" straight through exhaust to a 70mm (6.2mm smaller diameter) Invidia have much effect power wise?
Old Mar 28, 2010 | 05:02 PM
dsddcd's Avatar
Without means to quantifing muffler performance or the losses from piping.
Assuming all else is equal there will be no difference.
Old Mar 28, 2010 | 05:33 PM
camuman's Avatar
less sound/drone and most likly same performance. DO IT.
Old Mar 28, 2010 | 05:51 PM
chris_barry's Avatar
Just turn the boost up 0.1 psi to compensate.
Old Mar 28, 2010 | 05:52 PM
PsykotiK's Avatar
i wanna say you'd lose a few horses.. but u should be ok.. make sure u check the afr just because sometimes it throws off a lot
Old Apr 16, 2010 | 12:59 AM
AusS2000's Avatar
Absolutely loving the Invidia. It has a custom resonator/mid-muffler and is nice and quiet.
Old Apr 16, 2010 | 05:06 AM
Momentum's Avatar
6mm may seem like nothing but its actually a 16% reduction in area. Not insignificant IMO. Whether or not you are flowing enough air for that to help, hurt, or do nothing I don't know.
Old Apr 16, 2010 | 04:17 PM
AusS2000's Avatar
Any loss of power is not noticeable on the bum dyno. It actually feels like an increase because the car still has plenty of power but doesn't make a great deal of noise making it.
I'll retune soon and we'll see if there is any loss. Mind you, I've had a new turbo, new exhaust and readjustment of the tappets since my last tune.
mtw11c
Feb 12, 2013 02:45 PM
AusS2000
23
Apr 19, 2010 09:16 PM
Addictuned S2K
Dec 7, 2009 10:44 AM
kartrcr4life
Oct 2, 2008 02:16 PM
ReD AP1
May 8, 2007 02:52 AM
