-8 oil return
Old Jul 18, 2010 | 09:11 PM
ghettocrxsi's Avatar
Default -8 oil return
At work we do tons of -8 stuff on our hydraulic systems. I have always used -10 for all my turbo cars.
Would it be a problem to go to this size? This is one of the last things I need to figure out on my car.
Its a 1/2" line.
Old Jul 18, 2010 | 09:18 PM
Spoolin's Avatar
I've been using a -8 return line to the girdle on my JB turbo's for 7 years with not one problem and I also use a -3 feed from the relocation block with no restrictor. -8 lines are also used on my relocation kit for 7 years with no problems.
Old Jul 18, 2010 | 10:52 PM
Raven628's Avatar
-8, I had something bigger, I think -10 and may have been the result of my oil pressure dropping and causing a rod to spin years ago.
Been -8 since 05 and have not had oil pressure problems since.
Old Jul 19, 2010 | 12:01 AM
Alright perfect thanks guys, I have a hydraulic crimper and will make up my own lines then save a little money.
Old Jul 19, 2010 | 04:12 AM
teamvalorracing's Avatar
you cant go too big on the return. it doesnt effect your pressure unless its too small on journal bearing cartridges.
Old Jul 19, 2010 | 09:50 AM
siadam's Avatar
Bigger the better on the return.
I use -10 stuff myself.
Old Jul 19, 2010 | 10:15 AM
berlinas2k2's Avatar
-10AN here on all of my returns. -3 on all inlets
Old Jul 19, 2010 | 10:52 AM
^im with siadam and berlina
im running a 5/8"ID return line with -3 in.
Old Jul 19, 2010 | 11:43 AM
Ramocheese's Avatar
5/8" Minimum is what I would do. 3/4" is even better on journal bearing turbos.
liquidgsr
Jul 2, 2016 05:06 AM
TexaS2OOO
Jun 8, 2014 01:28 PM
Suzuka_Joe
Jun 19, 2013 01:44 PM
AusS2000
Jun 10, 2011 07:04 PM
