adding ac
Old Jul 26, 2006 | 09:11 PM
PAYELS2K's Avatar
Default adding ac
will i notice a difference...........comp sc adding ac
Old Jul 27, 2006 | 02:05 AM
Enthralled's Avatar
If your running stock boost not much of a diffrence....But if you plan on more boost then go for it.
Peace
Old Jul 27, 2006 | 05:38 AM
stitos2k's Avatar
You might on a super hot day, but otherwise probably not. You loose a little boost with the AC, which kind of offsets the cooler charge a bit. Now if you plan a little upgrade action, you'll definately want one.
Old Jul 27, 2006 | 07:31 AM
xviper's Avatar
Adding an A/C to an existing Comptech can drop the boost pressure by as much as 1 psi. This will translate into a bit of lost hp (15 to 20 maybe). If you're good with this, nothing else needs to be done. If you want that back, you'll need to get the smaller pulley from Comptech, put the car on a dyno and turn up the fuel pressure till everything reads good.
Old Jul 27, 2006 | 09:40 AM
PAYELS2K's Avatar
SO YOUR TELLING ME I SPENT 2000.00 DOLLARS ON A HEADER AND AC TO GO SLOWER............................DAMN
Old Jul 27, 2006 | 09:47 AM
WindchaserS2K's Avatar
Old Jul 27, 2006 | 09:48 AM
xviper's Avatar
Well, you didn't "have" to do the header.
Old Jul 27, 2006 | 10:46 AM
stitos2k's Avatar
Now go spend 100 bucks (probably less) on a smaller pulley(7psi max if you don't plan on getting the AEM thing) , 500 for dyno time and tune, and your all set!
Old Jul 27, 2006 | 12:58 PM
ayS's Avatar
ayS
hmm...but running a/c makes everything run "safer". would this be correct to say?
Old Jul 27, 2006 | 03:14 PM
xviper's Avatar
Yes, but that's not saying that running a Comptech without one is "unsafe". It's kinda like insurance.
\\s2kris//
Mar 29, 2010 09:05 PM
backman_66
Sep 16, 2006 07:14 PM
SpoonS
Mar 20, 2003 11:38 AM
jenniferbubalo
Jul 19, 2001 01:33 PM
