Adding AEM wideband 2300 to 1052
Old Dec 18, 2008 | 09:26 PM
EK9MAX's Avatar
Default Adding AEM wideband 2300 to 1052
ok so i'm adding a 2300 single-channel wideband to my 1052. I figure'd the wiring part out, but do i need to do any calibrations or any setting in teh aem software???
I'm planning on keeping the stock primary O2 and run this on teh 2nd O2 sensor aem port.
Old Dec 18, 2008 | 09:36 PM
Stratocaster's Avatar
You should remove the stock sensor. The EMS does not have a heater curcit for it, so it is just dead weight. It will just burn out if you leave it there. pull it and put is aside.
Yes. you wil have to calibration the EMS and Wideband so they are in snyc. I.E. You are have 0-5 volt curve on the EMS and a 1-3 volt curve in the wideband, it is not going to work right.
Old Dec 18, 2008 | 11:28 PM
EK9MAX's Avatar
ok good to know. i will pull the stock O2 sensor then.... I just had a spot on my used exhaust that had a wideband in there before.... so i guess i gotta get a plug for that....
Not about sync.... any help on how to do that?
I have a decent basemap on teh ems already, but it's set for teh stock O2 sensor...
Old Dec 18, 2008 | 11:35 PM
EK9MAX's Avatar
And what about all the guys running 1052's without a wideband.... Are their o2 sensor burning out?
snmalone
Aug 7, 2014 03:13 AM
skool u
Jun 23, 2010 10:46 PM
lvd1102
May 29, 2009 08:17 PM
afwfjustin
Jun 17, 2008 10:05 PM
Spec_Ops2087
Oct 26, 2007 08:41 PM
