AEM 2step... How bad is it?
Old Aug 19, 2010 | 11:35 AM
siadam's Avatar
Originally Posted by Deception,Aug 19 2010, 07:27 AM
^^ Nice vid.
Why a wheelie bar on a FWD? Does it help to keep the car straight?
What happens when a car squats off the line?
Weight is transfered from the front to the rear. Reason why a RWD is better than FWD.
The bars help stop the weight transfer, keeps it over the driveline where it's needed.
Old Aug 19, 2010 | 01:06 PM
Dan1987's Avatar
Originally Posted by CourageOO7,Aug 19 2010, 02:14 PM
I am no expert because I don't drag race but I imagine this is the same as a rev limiter (only premature, if you will). Anyway, I believe the way to minimize engine wear/damage is to make sure that timing is retarded well before fuel cutoff. Maybe call AEM and find out what they believe are optimal settings for this platform? They are usually quite helpful.
Nah, its not like a normal rev limiter... this is anti-lag. although the revs are limited to a certain point (where ever the driver choses), in an ideal world this would be the point of threshold traction.
When the revs reach this limit the fuel continues to be injected but the ignition timing is retarded back, usually by a good 25 degree's but obviously this figure can vary. this means that the charge is still burning when the exhaust valves are opening, in turn spooling up the turbo. absoloutely awesome, but notoriously hard on turbo's and exhaust valves.
Old Aug 19, 2010 | 01:15 PM
m R g S r's Avatar
Love flames shooting out my hood from the WG + launch control.
Old Aug 20, 2010 | 04:05 AM
Spec_Ops2087's Avatar
Correct, though not likely there have been instances of s2k's dropping exhaust valves due to a hard 2step. Just be aware...
Old Aug 20, 2010 | 04:57 AM
teamvalorracing's Avatar
Carey-
did you have flat-shifting enabled also? i couldnt help but notice the "anti-lag backfire" whilst shifting. bad-ass
joefish1298
Oct 2, 2011 01:54 AM
lotus7racer
May 20, 2010 01:37 PM
s2000 x
Jul 8, 2009 11:33 AM
nightcrawler7188
Jan 29, 2008 04:40 PM
97Snake
Dec 13, 2002 06:34 PM
