AEM boost gauge install?
Old Dec 8, 2011 | 03:24 AM
r_holguin's Avatar
Default AEM boost gauge install?
I installed my boost gauge last night went around the block to just see it only go up to 6-7 psi I mean I'm not running 30 psi but at 8.5 that's what I expecting it to say but never passed 7 so my question is did I install right? Did I tap the right vacuum line? The line I taped is the vacuum line from the intake manifold to the BOV and wastegate. Is there a different line it's supposed to go to? I know that I should be at 8.5 psi cause that's what my waste get spring is and no boost controller just wastegate. Any help is muchly appreciated thanks in advance
-Randy
Old Dec 8, 2011 | 04:38 AM
sohc_mshue's Avatar
Just because your wastegate spring is rated for a certain pressure it does not mean you will hit exactly that.
Old Dec 8, 2011 | 07:35 AM
9krevvin's Avatar
This!!
Old Dec 8, 2011 | 04:08 PM
r_holguin's Avatar
Ok thanks for the reply that's what I was thinking
RZA
Mar 29, 2016 06:41 PM
azride1983
Nov 11, 2008 04:18 PM
nMeOnE
Mar 9, 2008 05:04 PM
Silver S2k4
Apr 6, 2005 09:23 AM
Yellow Streak
Oct 23, 2002 01:30 PM
