aem ems
Originally Posted by phils2k,Oct 23 2008, 06:57 PM
if you have and i had this problem yesterday, whilst plugged into the ecu i went to the ecu tab and went to the conection port and checked it was the correct port then it connected
Still nothing.
Originally Posted by mys2k3,Oct 25 2008, 07:20 AM
I had did that as well and I changed it to "Com4: ATEN USB to Serial Bridge"
Still nothing.
Still nothing.
Control bar up top ECU-CONNECTION PORT-SERIAL. It should then give you one COM PORT that you can use. Worked on mine.
Originally Posted by mys2k3,Oct 25 2008, 08:26 AM
I did all that and tried com 4 and com 5 and got the same results. I think I'm just going to have to get another one.
Hmm... I have a Belkin one that didn't work and an I/O gear that does. A lot of the DHP guys (GM tuning software) use Keyspan USB-serial adapters.
You have to have the key on, connect the USB-serial cable, open the AEM software, choose serial and then the correct com port, and click connect. You should see flashing lights on the adapter.
Tim
Tim
Tim
Tim
The first time I started up Aem Pro I didn't plug in the adapter and it showed the different com ports. Now that the adapter is plugged in it won't show any other port other than the one it is plugged into(Com 4). If I unplug the adapter it doesn't show any com ports.
