aem ems
Old Jan 24, 2009 | 09:15 AM
  #21
mys2k3's Avatar
Originally Posted by Spec_Ops2087' date='Oct 23 2008, 08:00 PM
Most people just recommend using an actual serial port rather then a serial-->usb connector.
Granted most laptops don't come with serial ports anymore but you can always get a PCMCIA serial card for your laptop
Where did you get you serial card from? Most places I have checked wanted around $150-$250.
Old Jan 24, 2009 | 01:26 PM
  #22
candymanjl's Avatar
I think my USB to serial adapter shows up as COM4 if I remember right. the number doesn't really matter as long as you're picking the right one.
I'm using this on my Vista laptop and it's been flawless, not a single issue.
http://www.usbgear.net/USB_rs232.html
Old Jan 24, 2009 | 07:38 PM
  #23
ChefJ's Avatar
My tuner has a sweet ass toughbook with a touch screen and a serial port. This lap top looks like it was built for tuning. Compact and rugged. I may get one just for the car. I have always hated the usb-serial bs. Sometimes it will read sometimes it won't. Make sure your usb port on the back of your comp is tight.
Old Jan 25, 2009 | 05:03 AM
  #24
candymanjl's Avatar
most new laptops don't come with serial ports so you're screwed, you have to get some kind of adapter.
Old Mar 27, 2009 | 12:04 PM
  #25
mys2k3's Avatar
I found a laptop with serial cable. Turns out that the car itself, for some reason, isn't connecting to the ems. After talking with Aem they think it may be something with the oem harness or some kind of backfeed into the ems. I can't figure out what it is since the only things cut into the oem harness are the map sensor and injectors.
I even connected 12v directly to the ems from the battery to see if it would connect and it does but when hooked up to the harness I get nothing. Any ideas?
Old Mar 27, 2009 | 12:14 PM
  #26
LostMotion's Avatar
Perhaps this will help some other people out although it's not answering your immediate question, but you can get the PC Card Serial cards from ebay for about $15 shipped and they work flawlessly. The USB adapters are horrible.
It sounds like you have a power issue. Are you sure the power connection is working from the harness? Find the pin and test it with a volt meter. There may be more than one pin...
Old Mar 27, 2009 | 12:22 PM
  #27
mys2k3's Avatar
I did check the harness and I get 12v, 10v-11v to be exact. You are right there are two pins, but when I put power directly from the battery to either pin the ems connects. It just won't connect while in the car.
Old Mar 27, 2009 | 12:24 PM
  #28
LostMotion's Avatar
Have you tried just connecting the power pins from the harness (I think you only need the "bank 1 or 2" pin, not the "bank 3" pin, looking left to right at the connectors) and nothing else (injectors, etc)?
Old Mar 27, 2009 | 12:33 PM
  #29
mys2k3's Avatar
I did try that. I had just the "B" connector attached and still nothing.
Old Mar 27, 2009 | 01:58 PM
  #30
LostMotion's Avatar
I don't get my 12 volt from the harness, I bring it in from a 12v near the fuse box by the ECU. I'm not sure the 12v from the harness is sufficient. Where are you getting your 12v from?
