aem ems
Old Jun 5, 2009 | 01:43 PM
freshs2k's Avatar
Default aem ems
My questions is with the aem ems do you need a resistor box to run these injectors? Does it matter if there peak and hold or saturated? I bought my injectors so long ago I can't remember if there peak and hold or saturated. How can I check to see what they are by using the aem ems? By just checking the resistance?
Old Jun 5, 2009 | 08:38 PM
candymanjl's Avatar
just measure the impedance using a multimeter. if they're in the 3-5 ohm range you'll need the resistor box. if they're in the 12-16 ohm range then you don't need the resistor box.
after typing this I remembered in the AEM software it lists the resistance of the injectors in the primary injector wizard. the Siemens 756cc's are 3 ohm according to the software so yes you'll need the resistor box.
Old Jun 6, 2009 | 04:39 AM
freshs2k's Avatar
Yes thank you for the help. ill be sure to get a resistor box. How hard is it to wire something up like that?
Old Jun 6, 2009 | 07:44 PM
candymanjl's Avatar
it's not that hard, just some extra wiring to each injector.
Old Jun 7, 2009 | 10:08 AM
freshs2k's Avatar
Ok cool searching local junk yards now.
Old Jun 7, 2009 | 07:59 PM
TRBOKEV's Avatar
Are you sure they are 750's?
Most of the ones that are sold are the 60 lb/hour (Especially through Inline Pro)but with added fuel pressure (86 psi) can flow as much as an 880. I know the ones I have were touted as flowing 750 but were actually the siemens 60lb an hour which do NOT need the resistor box.
Old Jun 8, 2009 | 04:24 AM
freshs2k's Avatar
Im trying to find a definate answer because people keep saying they do need a resistor box some people saying they don't. they are 3 ohm so i don't know if that makes a difference low impedance. I haven't started the car yet.
Old Jun 8, 2009 | 05:53 AM
roi's Avatar
roi
If they are 3 Ohms then you definitely can not run them on the AEM EMS without a resistor box or the AEM peak and hold box.
Old Jun 8, 2009 | 06:31 AM
TRBOKEV's Avatar
Yeah my 60 lb an hour from Inline Pro are high impedance.
Aaron B
May 13, 2017 07:38 AM
SuzukaBlueAP2
Apr 13, 2010 05:39 PM
ShMooveS2k
Jun 22, 2007 04:17 PM
lexar13
May 22, 2005 04:31 PM
