AEM EMS and additional sensors
Old 01-13-2006, 12:38 AM
AusS2000's Avatar
Default AEM EMS and additional sensors
I've been mucking about with the 'Dash' function of the AEM EMS and using it to monitor various parameters. It can monitor and display any sensor that is connected to the ECU.
One thing I've realised is that we don't have a decent oil pressure sensor. It is just an on/off sensor. I'm wondering if I add an oil pressure sensor and also an oil temp sensor can I feed their output into some auxilary input on the AEM and calibrate and display the result? I assume other versions of the AEM for other cars have this so it's probably part of the base configuration.
Has anyone done this or similar? Are there any recommended sensors and applicable calibration file?
Old 01-13-2006, 07:38 AM
DaWorm's Avatar
Ok,
AEM is about to produce a multi guage. Capable of displaying any parameter that is fed to the AEM. It will run on the serial data line.
The AEM allows for 8 inputs i think, so yes.. you can put an oil pressure line and 'tell' the aem ( I thnk ).
Old 01-13-2006, 07:40 AM
DaWorm's Avatar
Try this link.. for a read up..
I'll eventually get this.. but i'm deciding how best to do it..
http://www.horsepowerfreaks.com/sale/AEM/E...gement_Displays
Old 01-13-2006, 08:13 AM
Scorpion's Avatar
You can add a oil pressure sensoe and use a avalible input. But unless you are really worried about it, I'd just run a gauge. The only advantage to running it into the EMS would be warnings and logging.
Old 01-13-2006, 01:34 PM
AusS2000's Avatar
Thanks Scorpion.
As mentioned, I've been mucking around with the 'Dash' feature, so all my gauges are going to be digital images on an LCD screen.
Old 01-14-2006, 02:54 AM
PSC
PSC's Avatar
You could use an AEM sensor. You should have the documentation in AEM\AEMPro\Instructions directory, the files you want to look at are 30-2114.pdf, 30-2115.pdf,30-2116.pdf. They cost about US$ 150 each.
Old 01-14-2006, 07:48 PM
AusS2000's Avatar
Wow, bit steep for a sensor but might be the best option.
chrispayze
04-10-2016 05:30 AM
UH-60DRIVER
03-28-2016 02:11 PM
wadzii
01-17-2013 11:02 AM
EPM04
07-06-2010 10:03 PM
Soul Coughing
03-22-2007 12:01 PM
Quick Reply: AEM EMS and additional sensors
