AEM EMS boost by speed using front ABS sensor
Is there anyone here with a s2k turbo setup using boost by speed, but successfully utilizing the front ABS speed sensor as an vehicle speed input for their AEM EMS 1 or 2? Im not sure if this is even possible. I’m just wondering what else is involved besides splicing the correct wire from the modulator or ABS control unit to my D-connector. Is there a signal converter or anything of that sort needed?
If anything I would splice it by the connectors themselves , the right side originates for the underdash connectors.
Your AEM doesnt have speed input yet? If it can accept a pulse generator , VSS would work , but it may output at a high rate if connected directly. The S2000 cluster changes this single pps for the cruise , soft top , ecu , eps to us, so cluster out would be the best.
I found the following which might be somewhat helpful:
https://www.s2ki.com/forums/s2000-fo...ntrol-1169169/
I have an AEM EMS v1 which doesn’t have boost by gear. Boost by speed works pretty good for what I got and I’m happy with it. I just want to see if there was a way to optimize it using the actually ground speed vs using VSS.
