AEM EMS boost by speed using front ABS sensor
Old Jul 17, 2018 | 05:15 PM
soulicious's Avatar
Default AEM EMS boost by speed using front ABS sensor
Is there anyone here with a s2k turbo setup using boost by speed, but successfully utilizing the front ABS speed sensor as an vehicle speed input for their AEM EMS 1 or 2? Im not sure if this is even possible. I’m just wondering what else is involved besides splicing the correct wire from the modulator or ABS control unit to my D-connector. Is there a signal converter or anything of that sort needed?
Old Jul 18, 2018 | 10:33 AM
AP1Chief's Avatar
Why not use the oem VSS?
Old Jul 18, 2018 | 10:54 AM
tehlonz's Avatar
If anything I would splice it by the connectors themselves , the right side originates for the underdash connectors.
Your AEM doesnt have speed input yet? If it can accept a pulse generator , VSS would work , but it may output at a high rate if connected directly. The S2000 cluster changes this single pps for the cruise , soft top , ecu , eps to us, so cluster out would be the best.
Old Jul 18, 2018 | 02:00 PM
AP1Chief's Avatar
Im still lost to why you are not just using oem VSS?
Old Jul 18, 2018 | 02:52 PM
soulicious's Avatar
I am using the OEM VSS. If you lose rear wheel traction, EMS sees the speed increase which in turn increases boost.
Old Jul 18, 2018 | 03:06 PM
soulicious's Avatar
I found the following which might be somewhat helpful:
https://www.s2ki.com/forums/s2000-fo...ntrol-1169169/
Old Jul 18, 2018 | 03:23 PM
AP1Chief's Avatar
Do boost by gear than, or limit boost so your not spinning?
Old Jul 18, 2018 | 05:32 PM
soulicious's Avatar
I have an AEM EMS v1 which doesn’t have boost by gear. Boost by speed works pretty good for what I got and I’m happy with it. I just want to see if there was a way to optimize it using the actually ground speed vs using VSS.
Old Jul 19, 2018 | 09:59 PM
Singh_snisen's Avatar
Buddy is running 800whp boost by gear
boysie
Oct 2, 2016 12:40 PM
a.k.s2000turbo
Dec 1, 2010 07:20 AM
jb34304
Jun 5, 2010 04:21 PM
Spec_Ops2087
Oct 26, 2007 08:41 PM
stevharr
Aug 29, 2006 07:36 PM
