AEM EMS question...
Old Oct 12, 2009 | 09:04 PM
TRBOKEV's Avatar
Originally Posted by dsddcd,Oct 12 2009, 08:55 PM
Sorry, I ended up getting the flu and I have done nothing the last week. Let me know if I can help and I will see if I can keep you rolling.
Other than the wires themselves, I will have your ignition system wiring done this weekend. As soon as I get the mounts I will make your wires and send everything.
You ARE the man, Thanks Scott.
Hopefully the mounts will be completed this week. I'll try and push them along, but work is picking up so everyone is busy.
Hope your feeling better bud.
Old Oct 12, 2009 | 09:46 PM
AusS2000's Avatar
Anyone know if the Greddy oil pressure sensor is the same? It is 3 wire: Red, Black and White.
Old Oct 13, 2009 | 07:51 AM
jari8378's Avatar
Kev, if you need help, i can come by if you need another set of hands.
Old Oct 13, 2009 | 08:03 AM
dsddcd's Avatar
Yes, it is the same and the calibrations is given this thread
https://www.s2ki.com/forums/index.php?showt...&#entry14561782
Old Oct 13, 2009 | 08:14 AM
Irishflame27's Avatar
Originally Posted by dsddcd,Oct 12 2009, 08:41 PM
Here is an alternatative to the great info Irishflame27 ( ) posted.
THAT IS AWESOME INFORMATION! THANKS SO MUCH!
i never thought about using everything on the D connector, which in reality i wish i did it that way, the only thing on my D connector is the D16 pin, the other wire on the boost solenoid goes to a switched 12v on the under-dash fuse box (as well as my serial gauge)
Now to wire the hi boost switch, you simply wire to pin D11 and a chasis ground with a simple rocker switch? How do you set it up in the EMS to trigger the new settings?
Old Oct 13, 2009 | 08:25 AM
dsddcd's Avatar
Since TrboKev is in Nazifornia he has to make everything easy to remove so he can get smogged so that is why I offered the alternative.
Yep, a simple rocker switch or any 2 pole will work, or if you want to get fancy you can use a momentary switch with a latching relay and then wire the unlatching circuit back into an overboost output.
Old Oct 13, 2009 | 02:09 PM
AusS2000's Avatar
That appears to be for the Greddy MAP. I have the oil pressure sensor.
Old Oct 14, 2009 | 06:12 AM
goldsS2000's Avatar
This info is useful as hell
Subscribed.
Old Oct 14, 2009 | 07:21 PM
Sarek's Avatar
Kevin, LMK if you still need one, I think I have an extra D plug with a few pins left
Old Oct 14, 2009 | 10:51 PM
TRBOKEV's Avatar
Sweet! Thanks Paul, I'll shoot you a pm tomorrow.
