Aem ems and temp gauge
Old May 22, 2008 | 01:31 PM
Toad17's Avatar
Default Aem ems and temp gauge
ok well this is for the guys who are boosted ... I never had this prob before but recently my temp gauge has been going crazy. It will spike all the way up than go back down etc. Has this happen to anyone else?!! As far as I know with aem ems the temp gauge does not work so idk just thought id ask! Thanks
Old May 22, 2008 | 02:30 PM
sunhita's Avatar
1st is fix your ground voltage. It may be intervened with other devices.
2nd, if you are using AEM EMS, it may work to use Modifry ECT.
Good Luck !!!
Old May 22, 2008 | 05:25 PM
AusS2000's Avatar
Unless you have an ECT your temp gauge shouldn't work at all with the AEM EMS.
I have heard thought that some tuners set the temp gauge to full at a certain temp. Sounds like what you are experiencing.
Old May 22, 2008 | 10:38 PM
Planets's Avatar
Yeah, my temp gauge goes full hot within a minute or two of starting it up, never seen it go back down though without shutting off the engine. Modifry ECT definitely seems the way to go, I need to do it myself at some point.
Old May 23, 2008 | 06:17 AM
faukengenius's Avatar
I had this issue and it caused my car to go into limp mode. My tuner stripped my car down and it turned out to be a bad ground.
Off topic but to the OP. How much psi are you boosting to acheive your numbers and what's your setup if you don't mind me asking?
Old May 23, 2008 | 06:52 AM
camuman's Avatar
pretty sure when you put in the aem ems, the temp guage becomes just a warning light. basically you see one bar until its at a certain temp then it goes full on. mine sits at one bar, and i use the serial gauge to see what temp is. i bought the modifry fix just havent installed yet.
if your getting full temp light, either bad ground or the car really is overheating. have you checked the temp through aem software when temp gauge on dash is full lit?
Old May 23, 2008 | 08:38 AM
tbtak's Avatar
[QUOTE=sunhita,May 22 2008, 02:30 PM]1st is fix your ground voltage.
Old May 23, 2008 | 12:30 PM
Kwando's Avatar
i've seen it a few times with my ECT module... i think its a bad ground, but i cannot track it down.
Old May 23, 2008 | 12:50 PM
sunhita's Avatar
I know it may sound easy to say.... it is bad ground wiring.
However, which ground wire is bad?
I had tried 3 different ECT and pull wiring etc. At the end, my temp gauge on the cluster is still not moving at all.
So, if you tried it and it does not work..., just be ready to be disappointed
I am not trying to disappoint you. However, it is what I am experiencing...
Old May 23, 2008 | 05:49 PM
Toad17's Avatar
Thanks for the replies everyone i guess i will start checking things out... and def gonna get modifry... its weird it just happens for like few secs than goes back down... theres a ghost inside lol.... and about my numbers
at 14psi i made 370
and at 22 psi i made 460 on (118 octane)
i have a full inline pro kit with their exhaust and the gt35 journal turbo...
3mm hg and 675 cc inject. thats about it..
s2konroids
Aug 19, 2012 07:47 AM
s2konroids
Aug 16, 2012 04:34 PM
spapdx
Oct 5, 2011 03:17 PM
Rajdlos
Jun 28, 2008 08:07 PM
Kondor999
Jan 25, 2008 08:43 AM
