aem a/f ratio gauge question
Old Mar 23, 2006 | 08:49 PM
D-S2K's Avatar
Default aem a/f ratio gauge question
i'm running the comptech w/ ac on 6 psi, and i installed the aem a/f ratio gauge today. i pluged the sensor into the 2nd bung (the nearest one to the straight pipe)in my J's racing header.
the gauge is brand new, and i believe there's nothing wrong with it. when i start up the car, it will read 14.x and the number will gradually go down.
i drove the car for about 3 hours after the install. under normal driving, the gauge will read 10.0 all the time, with the occasion reading of 11.x
but when i push the pedal all the way down and go past 6k to 8k, the a/f gauge still reads 10.0, and not a difference.
now my question is if my readings are normal and correct? if not, what's wrong?
Old Mar 23, 2006 | 10:01 PM
xviper's Avatar
I think they're wrong. There's got to be a malfunction in the AEM gauge or your car is actually running that rich. I think it's the gauge.
Under steady state running at operating temp, the reading should fluctuate quite a bit - bouncing up and down in around the 14.x
When you let off the gas, the gauge should show "----" because the injectors shut down.
At WOT, mine goes down to around 12.0.
Your start up a/f seems to be about right.
You should double check the wiring to make sure they are all connected to the right places.
Old Mar 24, 2006 | 08:00 AM
D-S2K's Avatar
thanks X, i'll check everything again.
Old Mar 24, 2006 | 10:40 AM
Quivers's Avatar
Banned
I think that you are running uber rich. Im pretty sure the aem guage doesnt go below 10 to 1. I would adjust your fmu, back it off 1/4 turn then run it. see if it goes up.
Also, check your plugs to see if they are showing signs of burning rich.
Old Mar 26, 2006 | 07:28 PM
revhi's Avatar
The sensor needs to be on an angle, not sure if your headers setup to support it. I had mine welded to my test pipe. Ill post pics tomorrow if you need to see.
Old Mar 26, 2006 | 08:02 PM
xviper's Avatar
I think most a/f gauge 02 sensors are to be mounted within 18" of the exhaust ports (ie, best mounted in the header near where the stock primary sensor is located).
Here's a thread I did on my UEGO install:
https://www.s2ki.com/forums/index.ph...&f=71&t=267255
JspecVtec
Sep 14, 2012 02:05 PM
vxn12
Dec 29, 2010 07:05 PM
joefish1298
Nov 16, 2010 08:42 AM
S2KB00ST
Apr 9, 2009 02:16 PM
camuman
Feb 19, 2009 10:33 PM
